Currie Front End JJ housing kit? Currie/Savvy Arms - JeepForum.com
post #1 of 42 Old 08-16-2011, 04:24 PM Thread Starter
drewtj05
is this kit required to install Currie JJ upper arms or is it just an optional upgrade from stock?
Also, I am debating between the Currie JJ uppers or the Savvy/Currie Upper arms that are made from aluminum and have adjustable joints on both ends rather than one.
drewtj05 is offline
post #2 of 42 Old 08-16-2011, 04:53 PM
Jay12
It puts a JJ on the axle end instead of the stock bushing. It isn't required.
The Savvy arms can be adjusted while on the vehicle with the adjustable JJ's on each end. The basic Currie arms need to be unbolted to be adjusted.
Jay12 is offline
post #3 of 42 Old 08-16-2011, 06:19 PM Thread Starter
drewtj05
Thanks for the reply.
You think the Savvy ones are really worth it if I don't plan on lifting my Jeep more than what I am going to?
I was also looking at different vendors and came across Frankenstein Offroad. I can get the standard Currie Upper Adj. for about 40buck cheaper than savvy plus free shipping. Anyone have experience with these guys?
drewtj05 is offline
post #4 of 42 Old 08-16-2011, 06:24 PM
NotURMailman
NotURMailman's Avatar
It's up to you if it's worth it or not. If you're going to do your own work, the ease of adjust-ability will save you a ton of time and frustration. I wish I had them for all of the time I've spent trying yo get my junk adjusted right. I will be getting them.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #5 of 42 Old 08-16-2011, 06:34 PM
Unlimitedlou
Currie now has adjustable arms for the rear while they are bolted to the axle. I would have bought the Savvy's when I did mine, but I was a month to early on Savvy's release. I really like the bling factor of the Savvy arms. Back to your question, the front axle JJ upgrade is optional, but it makes axle articulation alot better and gets rid of the junk OEM bushings.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #6 of 42 Old 08-16-2011, 06:47 PM
Imped
Imped's Avatar
Not necessary. It gets rid of the remaining bushings and tightens up the front end, making it next to impossible for DW to get a chance as long as you have a good track bar and steering.
OlllllllO
IndyORV
Imped is offline
post #7 of 42 Old 08-16-2011, 06:51 PM Thread Starter
drewtj05
Is there a high chance of DW if i stick to the stock bushing setup?
drewtj05 is offline
post #8 of 42 Old 08-16-2011, 06:58 PM
biffgnar
biffgnar's Avatar
If everything else (control arms, steering, track bar) are quality parts in good shape probably not. But if all that is true and you do get DW then you probably have a reasonable guess what the cause is. If the rest of your front end is a mess though then who knows.
Romney in 2020!
biffgnar is online now
post #9 of 42 Old 08-16-2011, 06:59 PM
Imped
Imped's Avatar
If they allow play, yes. Not necessarily full blown DW, but wobble to a lesser degree. If you wheel, they'll only be overstressed and.will fail eventually. Mine were toast and I thougt my front end felt solid before. After the JJ's, it was a different story.
OlllllllO
IndyORV
Imped is offline
post #10 of 42 Old 08-16-2011, 07:34 PM Thread Starter
drewtj05
Almost all the suspension parts on my jeep are going to be replaced when I lift my Jeep so that will be good.
With the JJ's did you notice a difference in the handling of your jeep?
drewtj05 is offline
post #11 of 42 Old 08-16-2011, 07:44 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Our aluminum double ended adjustable are close in price to the standard Currie arms or CE-9103S DOM arms (S=Savvy by the way.)
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #12 of 42 Old 08-16-2011, 07:53 PM
Benderff
Benderff's Avatar
Having used both, the double end adjustables are well worth it. I have always thought adjusting the pinion angle was a pain, not hard, just a pain. I needed new rear uppers and went they a set of the double ends. After installing my underarmor I needed to adjust the pinion again. It took minutes! Super easy and way faster.
Benderff is offline
post #13 of 42 Old 08-16-2011, 08:33 PM Thread Starter
drewtj05
So with standard ones you literally have to take the entire arm off and adjust it?
I was noticing that their prices are pretty close hmm what to do.
drewtj05 is offline
post #14 of 42 Old 08-16-2011, 08:39 PM
LJALLEN
No, you only have to remove one end to adjust.
Do yourself a favor and go SAVVY!
LJALLEN is offline
post #15 of 42 Old 08-16-2011, 09:08 PM
Benderff
Benderff's Avatar
Like said above just one end, but it never lines back up after it's adjusted. I always had to use a ratchet strap, or some other red neck system to make it work.
Benderff is offline
Savvy/Currie 3" TJ/LJ Suspension Lift Savvy TJ Wrangler Technical Forum 1339 03-30-2017 12:10 PM
Currie/Savvy Lift Install Advice... CGSteve TJ Wrangler Technical Forum 1 06-20-2011 11:21 PM
Currie front end housing kit question. mike481 TJ Wrangler Technical Forum 4 03-24-2011 12:47 PM
Savvy Ultimate Currie Steering Kit question bbuske TJ Wrangler Technical Forum 3 12-06-2010 11:22 AM
currie d44 front housing. cmc1 TJ Wrangler Technical Forum 0 12-18-2008 04:33 PM
