Currie Control Arms Install tips - Page 6 - JeepForum.com
post #76 of 89 Old 08-21-2012, 05:50 PM
MJBinNM
Originally Posted by hold24 View Post
I'm going to keep this thread alive with a question on installing the currie upper control arms... What size drill bit do you use on installing the 7/16 bolts to the axle... Is it difficult drilling out those sleeves?
When installing the front uppers, if you aren't adding the axle housing JJ kit, you don't need to drill anything, just install with the original bolts. If you do install the JJ kit, use the greasable bolts that come with the JJ kit.
On the rear you just drill the upper axle mount holes to 7/16". You will not be drilling any sleeves. If you use a long 7/16" drill bit it makes it a lot easier. Those were the only holes I had to drill.
MJBinNM is offline
post #77 of 89 Old 08-21-2012, 06:19 PM
hold24
1977 CJ7
but it appears the savvy control arms will not take the factory bolts and the holes appear to be a little larger....
1978 cj7 Black Renegade levis ....304 3spd hardtop ps pb tilt tac and clock ac...
1979 cj7 Cumberland green Golden Eagle 18k Original miles V8 auto..100% rust free Oregon Jeep..
hold24 is offline
post #78 of 89 Old 08-21-2012, 06:21 PM
brplatz
I just did my savvy fronts, lowers we're easy. Uppers I used the greasables on the frame side without any drilling and the stock one on the axle side. Little bit of slop on the axle side but I thought I saw somewhere Blaine said it doesn't matter. Who knows
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #79 of 89 Old 08-21-2012, 06:32 PM
btn
double post
2000 TJ, 4.0L, 4" short arm suspension lift, 35" tires, Rear D44 and front HP30 both with ARBs and chromo shafts, NV3550.
btn is online now
post #80 of 89 Old 08-21-2012, 06:34 PM
btn
One thing I did was to unscrew the joint from the arm and anti-seize all of the threads before screwing it back in. That way all the threads are protected from galling and cold welding and rust, and if you have to adjust them later on, it will be much easier.
btn is online now
post #81 of 89 Old 08-21-2012, 06:40 PM
brplatz
My Savvy arms came anti-seized Go Gerald!
MOΛΩN ΛΑΒΕ
brplatz is offline
post #82 of 89 Old 08-21-2012, 06:52 PM
tjcj
Mine too
Yakima Valley Mountaineers.
tjcj is online now
post #83 of 89 Old 08-21-2012, 07:00 PM
MJBinNM
Not sure what model you're putting them on. The holes in the arms are for a 7/16" bolt and the original bolts on my '06 are 10mm (I think). There was a little play, but if you torque them down to spec you'll be fine.
I have to admit that I only ran it that way for a few weeks until I got the axle JJ kit installed...for $160, I think it's well worth it to get JJs on all ends of all arms.
MJBinNM is offline
post #84 of 89 Old 08-22-2012, 07:00 AM
hold24
1977 CJ7
Did you just pull the flanges off the factory bolts and use them....Its a 06 Rubi LJ
hold24 is offline
post #85 of 89 Old 08-22-2012, 08:02 AM
geiman
If you're also replacing the rear upper arms, use one of the bolts from the rear uppers for the front upper axle side instead of the one with the flange. That way you can tighten them up easier.
If you can't do that, I have used vice grips to clamp the flange in place while I tighten things down.
geiman is offline
post #86 of 89 Old 08-22-2012, 08:31 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The Currie bolt will work in the hole at the frame end. That leaves both OEM bolts to use at the axle end. Use the bolt from the front of the upper arm and the nut from the back of the upper arm and make one bolt for the axle side.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #87 of 89 Old 08-22-2012, 08:33 AM
geiman
Completely forgot about that bolt, good point.
geiman is offline
post #88 of 89 Old 08-22-2012, 09:09 AM
MJBinNM
Good choice in Jeeps As others have said, just use the bolt from the other end of the uppers...
MJBinNM is offline
post #89 of 89 Old 08-23-2012, 04:38 PM
hold24
1977 CJ7
Wow, I did not even think of using those.... After installing the kit my brain is misfiring a little...
hold24 is offline
Currie control arms bhall687 TJ Wrangler Technical Forum 11 05-19-2010 01:32 PM
Anyone seen or used these? (Currie control arms) remery829 TJ Wrangler Technical Forum 5 12-28-2009 09:38 PM
Currie or JKS control arms millhouse1 TJ Wrangler Technical Forum 3 10-13-2007 08:26 PM
Currie control arms crgrissom TJ Wrangler Technical Forum 0 03-17-2007 09:00 AM
Anyone with Currie control arms? kpatrick TJ Wrangler Technical Forum 5 12-22-2004 12:26 PM
