Currie Control Arms Install tips - Page 5 - JeepForum.com
post #61 of 89 Old 10-12-2010, 03:10 PM
Imped
Imped's Avatar
Giving uppers or lowers the title or job of "wheelbase" or "pinion angle" will confuse people. If you lengthen the front uppers, that will rotate the pinion up, which will lower the caster, which will slightly decrease the wheelbase. If you lengthen the front lowers, that will rotate the housing the other way--extend wheelbase, lower pinion angle, and increase caster angle. The same goes for the rear, except there is no caster angle in the rear. All control arms are are links that locate and constrain the axle. Neither the upper or lower links do only one thing....if you push the rear axle back by lengthening the lowers, you'll also lower the pinion so you'll need to extend the uppers to compensate. This isn't a difficult concept to understand if you just think about it in a logical way. And there is no formula for control arm length for xx height. Other factors, such as wheelbase, desired pinion angle/caster, and up travel factor in. Just get down there and start messing with them. As long as you stay consistent with the arm lengths, you won't mess anything up.
OlllllllO
IndyORV
Imped is offline
post #62 of 89 Old 10-13-2010, 12:06 PM
UncleWilson
UncleWilson's Avatar
Question for clarification and please feel free to correct where needed.
All 3 (front caster, front pinion, and rear pinion) are calculated at ride height, correct? For the front the 2 constraints are pinion angle and caster angle (trying to balance a good pinion angle with as high of caster attainable ). In the rear is constraints are rear pinion and clearances to gas tank. For both front and rear another things to watch are, tire location at full stuff in wheel well, and track bar interferences.
Sounds stupid but I want to best understand this before the trial and error happens.
Also, is it easier/harder/indifferent to change CA lengths with coils and shocks installed?
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #63 of 89 Old 01-04-2011, 02:00 PM
viperbluelx
No you don't care what the length is, all you care about is that both control arm bushings have the same tension on them so you aren't preloading them so they fight each other which will cause them to wear prematurely.
This just saved my day!
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #64 of 89 Old 05-01-2011, 02:40 PM
deron1
In the process of installing the Currie LCA (Front). Can somebody tell me where the extra large washer goes? Wheel side, diff side? Inside, outside smaller washer?
Any help is appreciated
2005 Jeep Rubicon Unlimited - Sahara Edition. #923/1000.
deron1 is offline
post #65 of 89 Old 05-02-2011, 06:17 AM
AZJeepNewbie
It goes on the inside (diff side) of the axle LCA mount, directly against the mount. It should fit snugly into a slotted recess that you will see there (which is part of the factory control arm alignment mechanism.)
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #66 of 89 Old 05-06-2011, 06:08 PM
CsKWarEd
Got a pic of that washer location?
/\^/\'05 Silver Rocky Mountain Edition/\^/\
...my RME build thread... http://www.jeepforum.com/forum/f22/my-new-silver-rme-806705/
CsKWarEd is offline
post #67 of 89 Old 05-06-2011, 06:14 PM
biffgnar
biffgnar's Avatar
Its not that hard. There should be a horseshoe on the mount (for cam bolts). The big washer should fit snugly into that horseshoe to keep things from moving around.
Romney in 2020!
biffgnar is offline
post #68 of 89 Old 05-06-2011, 06:20 PM
CsKWarEd
I understand that part, but there are 4 additional washers supplied, on top of the 2 washers per bolt.
CsKWarEd is offline
post #69 of 89 Old 05-06-2011, 06:25 PM
biffgnar
biffgnar's Avatar
Those are extra. Curries lowers fit both front and rear. The big washers not necessary in rear so you use the small ones instead. The hardware that goes into the pack is enough to work for either application.
Romney in 2020!
biffgnar is offline
post #70 of 89 Old 05-06-2011, 09:22 PM
CsKWarEd
Thanks for your help, they weren't noted as extra, but that makes sense for them being interchangeable between front and back.
CsKWarEd is offline
post #71 of 89 Old 09-03-2011, 06:46 PM
REDNWHITE
Control arms on uninstalled axles
Can you install the control arms on a axle that was not previously on the Jeep before actually installing the axle? In other words I will be putting in new axles but want to get some of the work done before taking the old ones out and putting the new ones in to save on time.
Thanks
REDNWHITE is offline
post #72 of 89 Old 09-03-2011, 09:05 PM
mikesbeachhut
One at a time with tires on the ground.A DEEP socket set w/ breaker bar,box wrenches.Use your bottle jack under breaker bar to break lose tight nuts .
mikesbeachhut is offline
post #73 of 89 Old 06-16-2012, 11:06 AM
MJBinNM
gonna revive this old thread...lotta good info here.
I'm finally at the point that I can do this much needed upgrade and was looking at the Savvy site and noticed they now have aluminum Curries. Is there any trade-offs to these or are they every bit as stout as the steel ones? Also, did I read correctly that all the uppers are now aluminum?
Does anyone here have any personal experience with the aluminum ones?
TIA...Mark
MJBinNM is offline
post #74 of 89 Old 06-18-2012, 07:24 AM
geiman
You can still get steel arms if you wish. There are no real drawbacks to using the aluminum arms from Savvy; the nice thing about them is they are all double adjustable, which makes adjusting your pinion angle/placing the axle very easy and fast. I've had them for a while now and they've been great. I've drug them across rocks more than a few times without any issues.
geiman is offline
post #75 of 89 Old 08-21-2012, 04:34 PM
hold24
1977 CJ7
I'm going to keep this thread alive with a question on installing the currie upper control arms... What size drill bit do you use on installing the 7/16 bolts to the axle... Is it difficult drilling out those sleeves?
1978 cj7 Black Renegade levis ....304 3spd hardtop ps pb tilt tac and clock ac...
1979 cj7 Cumberland green Golden Eagle 18k Original miles V8 auto..100% rust free Oregon Jeep..
hold24 is offline
Currie control arms bhall687 TJ Wrangler Technical Forum 11 05-19-2010 12:32 PM
Anyone seen or used these? (Currie control arms) remery829 TJ Wrangler Technical Forum 5 12-28-2009 08:38 PM
Currie or JKS control arms millhouse1 TJ Wrangler Technical Forum 3 10-13-2007 07:26 PM
Currie control arms crgrissom TJ Wrangler Technical Forum 0 03-17-2007 08:00 AM
Anyone with Currie control arms? kpatrick TJ Wrangler Technical Forum 5 12-22-2004 11:26 AM
