Currie control arms - JeepForum.com
post #1 of 12 Old 05-18-2010, 05:39 PM Thread Starter
bhall687
Currie control arms
I have a quick question, do you have to do any welding to get the currie control arms on. I thought that you would not, but was reading another thread and was confused as it looked like he had to.
bhall687 is offline
post #2 of 12 Old 05-18-2010, 05:43 PM
Imped
Imped's Avatar
No. Unbolt old, bolt up new.
OlllllllO
IndyORV
Imped is offline
post #3 of 12 Old 05-18-2010, 07:16 PM
AZJeepNewbie
There is an optional welding step. Bolting Currie arms on with no welding replaces 14 of your 16 rubber control arm bushings with Johnny Joints. The remaining two rubber joints are upper control arm bushings that are attached to your axle. In order to replace those last two bushings, you use this optional kit which does require welding on the passenger side. Currie Enterprises CJ Axle Parts
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #4 of 12 Old 05-18-2010, 07:24 PM
lumpster
lumpster's Avatar
you will have to drill out the upper bolt holes on the jeep frame, its pretty easy, you arent making the hole much bigger, some people dont have to drill but i did.
lumpster is offline
post #5 of 12 Old 05-18-2010, 07:58 PM
GMC7000
If I use these control arms will I be able to climb rocks that I can not climb now?
GMC7000 is offline
post #6 of 12 Old 05-18-2010, 08:13 PM
TJdualsport
lol nope just leave your wallet that much thinner
TJdualsport is offline
post #7 of 12 Old 05-19-2010, 11:46 AM Thread Starter
bhall687
Thanks AZ, I actually beleive that I saw it on your build page now that I see your name.
bhall687 is offline
post #8 of 12 Old 05-19-2010, 12:04 PM
AZJeepNewbie
Yeah, I figured as much. I know some folks go without the housing JJ kit for a while, then eventually end up adding it. So I figured I'd just do it all at once while the patient was open on the table. It's real easy to get to when she's stripped down like that.
post #9 of 12 Old 05-19-2010, 12:28 PM Thread Starter
bhall687
AZ,
Do you think that I should go with this type of lift if I will be driving it as a DD and doing some decent wheeling. I live in CO so everything is rugged as ****.
bhall687 is offline
post #10 of 12 Old 05-19-2010, 12:43 PM
AZJeepNewbie
Well, that's my plan as well, including a decent amount expedition type of wheeling where I go hundreds of miles on rough roads as fast as I can. I'm came very close to going with a long arm kit and paying somebody to install it. However, I managed to get a ride in one and it was no panacea either. From all that I hear, a SA kit can be made to give a decent ride on rough terrain if it's set up right. So I decided to give the SA setup the best shot I can and do it right from the get go.
So if it doesn't work out, then I'm going to be disappointed. However, like I've said before, 2 years worth of participating in web forums and talking to some extremely knowledgeable people are telling me this will be an excellent set up for what I want to do. So stick around. I'm sure we'll both be very interested in how it turns out.
post #11 of 12 Old 05-19-2010, 12:47 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I went with Rokmen arms. Rokmen is based in Denver
Rokmen Gear Up....Rok On
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 12 Old 05-19-2010, 01:32 PM
AZJeepNewbie
Did you go with the JJ on both ends, or JJ/Clevite combination? Also, is it the case that Rokmen doesn't have front axle housing solution?
I'm not knocking Rokmen, because I know they make good stuff. But I do like that Currie builds an entire system so I know everything is going to play together.
control arm , currie
currie control arms question XlostJeepX TJ Wrangler Technical Forum 1 02-12-2010 12:15 PM
Anyone seen or used these? (Currie control arms) remery829 TJ Wrangler Technical Forum 5 12-28-2009 09:38 PM
Currie or JKS control arms millhouse1 TJ Wrangler Technical Forum 3 10-13-2007 08:26 PM
Currie control arms crgrissom TJ Wrangler Technical Forum 0 03-17-2007 09:00 AM
Anyone with Currie control arms? kpatrick TJ Wrangler Technical Forum 5 12-22-2004 12:26 PM
