Currie arms popping, is this normal for Johnny Joints? - Page 3 - JeepForum.com
post #31 of 41 Old 04-22-2012, 10:19 AM
greg_kulosa
Originally Posted by pcoplin
Proper torque on the uppers (7/16 grade 8) is 75 ft/lbs, the lower 9/16 are 150 ft/lbs. If you only have your lowers at 80, might want to crank on them some more.
Really? The instruction sheet from Currie says 60 ft/lb for the upper 7/16 bolts, and 90 ft/lb for the lower 9/16 bolts.
Is the Currie sheet incorrect?
I'm doing the rear set today, so I'd love to know if I need to do them tighter.
greg_kulosa is offline
post #32 of 41 Old 04-22-2012, 10:58 AM
pcoplin
I don't know, I just buy grade 8 bolts and use the proper torque using a torque chart. Currie's numbers seem awful low if you're using grade 8.
FullStack MotorSports
pcoplin is offline
post #33 of 41 Old 04-22-2012, 11:09 AM
joshhtfld
C-clip must be it then, the bolt is torqued to spec and is not moving. I'm curious to how a c-clip would pop out, due to the fact I have not flexed the suspension yet. So what could be the cause? Why would both of my rear uppers pop a c-clip out?
VA Jeeper
joshhtfld is offline
post #34 of 41 Old 04-22-2012, 11:21 AM
SpeedJeep
SpeedJeep's Avatar
I think that's for the factory bolts. Currie specifies different numbers IIRC.
http://www.currieenterprises.com/instruction_sheets/currie_control_arms.html
Edit> I didn't realize the post had been answered already. The lower numbers might be due to the center ball. Too much torque might distort or break the center of the joints?
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #35 of 41 Old 04-22-2012, 11:35 AM
SpeedJeep
SpeedJeep's Avatar
I think there was a run that wasn't machined correctly. Contact Savvy or Currie.
post #36 of 41 Old 04-22-2012, 12:52 PM
alex211
1995 XJ Cherokee
My currie arms came with greasable bolts, I can see why they would need less torque due to being hollow for the grease fitting.
95 xj bone stock for now
alex211 is offline
post #37 of 41 Old 04-22-2012, 02:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not gonna happen. You need some pretty intense machinery to even drill them. They are case hardened and heat treated.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #38 of 41 Old 04-22-2012, 03:36 PM
wushaw
Rockin jeep
wushaw's Avatar
The bolts are grade 8 but what about the nuts? I know the bolts that came with my Clayton lift are grade 5 so a lower torque is needed.
wushaw is offline
post #39 of 41 Old 04-22-2012, 03:37 PM
pcoplin
Ah, that's probably true. I don't run bolts with holes already drilled in them.
pcoplin is offline
post #40 of 41 Old 04-22-2012, 03:38 PM
pcoplin
I use grade 8 nuts, too. If you are using grade 5 you would use the torque ratings for a grade 5. Duh.
pcoplin is offline
post #41 of 41 Old 04-22-2012, 05:32 PM
wushaw
Rockin jeep
wushaw's Avatar
Yes, but you have no idea how many folks would actually think of that....most are just used to looking at the head and never worrying about the nut portion.
wushaw is offline
currie , control arm
Help with rebuilding Currie Johnny Joints the_art_of_desi TJ Wrangler Technical Forum 28 02-13-2015 09:59 PM
Currie Johnny Joint Suspension mrunnell TJ Wrangler Technical Forum 3 05-03-2008 08:12 AM
RE S/F Joints vs. Currie Johnny Joints RedMountainYJ TJ Wrangler Technical Forum 9 12-12-2007 09:17 PM
RE superflex joints / Currie Johnny Joints HMTwin TJ Wrangler Technical Forum 2 04-24-2007 05:15 PM
Currie Johnny Joints to replace Skyjacker control arm bushings... Zinkart TJ Wrangler Technical Forum 7 03-05-2007 02:49 PM
