Currie arms popping, is this normal for Johnny Joints? - Page 2 - JeepForum.com
post #16 of 41 Old 07-13-2010, 05:13 PM Thread Starter
vetdezracer
I got them apart using the all thread method, thank you Mr. Blaine. I called Currie to see get some advice and found out a couple of interesting things. They no-longer use two different washer thicknesses, now they set up their Jonny Joints from the start with the thicker washers which explain why mine are so tight. Currie recommended using a moly based grease, moly graphite even better. They said that regular grease would result in them sticking.
The guy at Currie said this stuff is pretty expensive, but I found Sta-Lube Moly Graph for $4.99 at NAPA. Is this what I’m looking for or do I need a higher quality moly grease?
vetdezracer is offline
post #17 of 41 Old 04-18-2012, 09:26 PM
tazsport
tazsport's Avatar
What ever became of this problem you were having with your JJ's ? I'm having a similar issue with one of my front lower control JJ's.
2004 Wrangler Rubicon (A new beginning)
1997 Wrangler, 4.0L, Sport (SOLD)
tazsport is offline
post #18 of 41 Old 04-19-2012, 01:29 AM
SpeedJeep
SpeedJeep's Avatar
Just an FYI: Don't forget to check the jam nuts. I ruined an arm because I neglected to follow up after installation.
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #19 of 41 Old 04-19-2012, 08:29 AM
tazsport
tazsport's Avatar
I checked the torque on the bolt and it's at 90 lbs. When you say check the jamb nut, what is there to check other than the torque? I've never had a JJ apart, but after doing some research and emailing Gerald, I understand that this sound is most likely not coming from the internals of the JJ.
tazsport is offline
post #20 of 41 Old 04-19-2012, 08:36 AM
Imped
Imped's Avatar
If you would take a JJ apart, you'd see that there's nothing inside that can produce a "pop." Any pop will either come from the shank rattling inside the arm (loose jam nut) or the bolt and center ball moving against each other (loose bolt). Give the bolt an extra crank (quit worrying about the specific torque value so much) and give the jam nut a good crank (again, same advice on torque value).
OlllllllO
IndyORV
Imped is offline
post #21 of 41 Old 04-19-2012, 08:45 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The big problem with the front of lower control arms is you are trying to clamp something in place in a slot which has very little surface area and gets damaged easily by sleeve style arms that don't have the larger ends like the JJ does. Pop the arm off and look at the inside of the mounts and see if they are damaged.
Or, just tighten them up until they quit popping.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #22 of 41 Old 04-19-2012, 09:45 PM
SpeedJeep
SpeedJeep's Avatar
My jam nut was loose for too long and it wallowed out the tube. The threaded tube had an oval shape and no matter how tight I made the jam nut the threads would still "pop" over every bump. It sounded like someone smacked my axle lightly with a ball peen hammer. It wasn't visible but when you would turn the joint 360 degrees in the tube you could feel it. I chased that noise for a month. I finally had to remove the arm to figure it out.
The arm would also pop when I cranked the steering wheel back and forth while the Jeep was stationary.
post #23 of 41 Old 04-19-2012, 09:56 PM
csmith
Same issue here, I traced mine to the factory lca mount on the axle side. The rubber bushing was bottoming out when flexing and causing the frame side jj to contact the frame bracket. I' m ordering the front axle kit ASAP
csmith is offline
post #24 of 41 Old 04-20-2012, 06:24 AM
Imped
Imped's Avatar
All the better reason to do a HP30 swap. The factory mounts didn't have a slot.
OlllllllO
IndyORV
Imped is offline
post #25 of 41 Old 04-20-2012, 06:15 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I did it for the driveshaft clearance:
Knuckelhead is offline
post #26 of 41 Old 04-20-2012, 06:29 PM
ytowntj
I had to go to about 80 ftlbs to shut mine up. The joints never made a sound though
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #27 of 41 Old 04-22-2012, 07:49 AM
tazsport
tazsport's Avatar
Well, problem solved. Even though I had re-torqued all the control arm bolts as spec'd in the Currie instructions and checked all the jam nuts, it wasn't enough. I cranked on the bolts at each end of the control arm making the creaking sound and she's quite now. Thanks for all the replies. Can't say enough on how happy I am with this 3" Savvy Offroad/Currie lift. Gerald, thanks for the awesome customer support !!!!
tazsport is offline
post #28 of 41 Old 04-22-2012, 08:56 AM
pcoplin
Proper torque on the uppers (7/16 grade 8) is 75 ft/lbs, the lower 9/16 are 150 ft/lbs. If you only have your lowers at 80, might want to crank on them some more.
FullStack MotorSports
pcoplin is offline
post #29 of 41 Old 04-22-2012, 09:17 AM
joshhtfld
Hate to hijack a thread but similar issue with my joint, so I figured I'd ask. My rear aluminum uppers at the axle side have about half a inch to a inch of play on them. I can grab them by hand and move them vertically. I was going through the check list this morning when I noticed it on both rear uppers.
VA Jeeper
joshhtfld is offline
post #30 of 41 Old 04-22-2012, 10:07 AM
Imped
Imped's Avatar
OK.....
What kind of play? Play around the bolt or play around the center ball of the joint? Either your bolt is too loose or you popped out a C clip.
OlllllllO
IndyORV
Imped is offline
currie , control arm
Help with rebuilding Currie Johnny Joints the_art_of_desi TJ Wrangler Technical Forum 28 02-13-2015 09:59 PM
Currie Johnny Joint Suspension mrunnell TJ Wrangler Technical Forum 3 05-03-2008 08:12 AM
RE S/F Joints vs. Currie Johnny Joints RedMountainYJ TJ Wrangler Technical Forum 9 12-12-2007 09:17 PM
RE superflex joints / Currie Johnny Joints HMTwin TJ Wrangler Technical Forum 2 04-24-2007 05:15 PM
Currie Johnny Joints to replace Skyjacker control arm bushings... Zinkart TJ Wrangler Technical Forum 7 03-05-2007 02:49 PM
