Currie arms popping, is this normal for Johnny Joints? - JeepForum.com
post #1 of 41 Old 07-11-2010, 09:12 PM Thread Starter
vetdezracer
I installed a complete set of Currie arms about 3-4K miles ago and they are now popping when flexed. When I take off from a stop I get a 4 or 5 “Klink” sounds. It’s been happening for the past month, getting progressively more noticeable. I had my son jack up one side of the axle and looked to see what was going on. The joints in the lower front arms are not moving freely, rather building up tension and then letting go in a pop or Klink sound. I greased them on install and re-greased them today, but it didn’t help. Is this normal?
vetdezracer is offline
post #2 of 41 Old 07-11-2010, 09:17 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
mine are quiet....did you run them though the range of motion as you greased them?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 41 Old 07-11-2010, 09:25 PM Thread Starter
vetdezracer
Good idea, but no I just greased them with the Jeep level. I did drive it after and did a bunch of right to left turns to move things around though.
Back to the garage to jack, flex and re-grease. Hopefully it will work, I really don't want to pull the arms out to service them.
post #4 of 41 Old 07-11-2010, 09:28 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
elaborate or instructions, please? this might help me with my RC X-flex arms, some wont even take grease.
Mail crawling.
MisfitSeven is offline
post #5 of 41 Old 07-11-2010, 09:29 PM
Unlimited04
1. Load grease gun with grease.
2. Put grease gun fitting on grease zerk of arm.
3. Rotate arm joint with spherical center ball fixed in place.
4. Squirt grease into joint until it pushes out someplace else.
5. Repeat 3-4 as necessary.
Useful Write-Ups:
Funny:
post #6 of 41 Old 07-11-2010, 09:30 PM
Imped
Imped's Avatar
That's odd. I've never heard a peep from any of my joints. Due to the JJ's design, there definitely should be no noises.
And unlimited, that's easier said that done. As I'm sure you know, the joints are tighter than a virgin. Very, very difficult to move the arm around the joint.
OlllllllO
IndyORV
Imped is offline
post #7 of 41 Old 07-11-2010, 09:34 PM
Unlimited04
I tried it with a vice, but the center ball just spun inside the vice, no matter how tight I tried to hold it. I doubt other joints are that tight, especially the RC he's got.
to get the Currie's, I mounted them and went wheeling with a grease gun + rag, and just squirted them full at full droop and full compression in a poser pic position. I hit them every few weeks now...they're quiet as can be.
Useful Write-Ups:
Funny:
post #8 of 41 Old 07-11-2010, 09:37 PM
Imped
Imped's Avatar
I can assure you the RC and Rustys joints are not. You can grab the ball and rotate it with little force.
OlllllllO
IndyORV
Imped is offline
post #9 of 41 Old 07-11-2010, 09:50 PM Thread Starter
vetdezracer
Okay update on my Currie joints.
First mine are tight, almost impossible to rotate on the jeep. I removed one front tire, lowered it all the way and greased in intervals all the way up including stacking two 4x4 on the floor jack. Then cycled it up and down a good 10 times to work things in and unfortunately no luck. These things are binding and popping like party favors.
post #10 of 41 Old 07-11-2010, 09:53 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Only grease them through the greaseable bolts if possible. You will likely need to take them apart and clean the bolts out so grease will pump through them and while they are apart, give the ball and race a good coating of grease before you reassemble them.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #11 of 41 Old 07-11-2010, 10:05 PM Thread Starter
vetdezracer
[QUOTE=mrblaine;9772473]Only grease them through the greaseable bolts if possible. You will likely need to take them apart and clean the bolts out so grease will pump through them and while they are apart, give the ball and race a good coating of grease before you reassemble them.[/QUOT
Does this require special tools, I see Currie sells one for $79 but I'm hoping this can be done without that. Also does anybody know if Currie warranties their stuff. These don't even have 5k miles on them.
post #12 of 41 Old 07-11-2010, 10:09 PM
KKiowaTJ
Well if they wont take grease. Take them apart and clean, Lube and reassemble. Dont try and pump grease if it wont go easy, Could possibly ruin the joint, For other parts as well. Good luck
MOPAR!
KKiowaTJ is offline
post #13 of 41 Old 07-11-2010, 10:12 PM Thread Starter
vetdezracer
How hard are these things to take apart? Has anybody on the board done this? Any tips would be appreciated.
post #14 of 41 Old 07-11-2010, 11:01 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I frequently use a shop press and a couple of sockets to disassemble the ones I work on. There is also a way to do it with some all thread rod, a couple of nuts, and some sockets. And, you will need a good pair of snap ring pliers.
I am Savvy
mrblaine is offline
post #15 of 41 Old 07-12-2010, 06:33 AM
RubiconRazorbac
RubiconRazorbac's Avatar
If they pop when under load, check the jam nuts. I had one doing this right after the install. It wasn't the JJ, I had a loose jam nut.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
currie , control arm
Help with rebuilding Currie Johnny Joints the_art_of_desi TJ Wrangler Technical Forum 28 02-13-2015 09:59 PM
Currie Johnny Joint Suspension mrunnell TJ Wrangler Technical Forum 3 05-03-2008 08:12 AM
RE S/F Joints vs. Currie Johnny Joints RedMountainYJ TJ Wrangler Technical Forum 9 12-12-2007 09:17 PM
RE superflex joints / Currie Johnny Joints HMTwin TJ Wrangler Technical Forum 2 04-24-2007 05:15 PM
Currie Johnny Joints to replace Skyjacker control arm bushings... Zinkart TJ Wrangler Technical Forum 7 03-05-2007 02:49 PM
