Is Currie Anti-Rock upgradable from 2" BB to 3.5" RE Lift? - JeepForum.com
post #1 of 3 Old 06-03-2007, 03:25 PM Thread Starter
CopaTJ99
I currently have a 2" boost and fro my reading in this forum Currie Anti-Rock is the way to go. If I install one now, what do I need to change if I later moved up to a 3.5" RE lift?
I've read someone saving the original links for a later 4"lift and just fabricating a homemade link while rinding on 2" boost. Can some comment please?
Thanks.
Anthony
CopaTJ99 is offline
post #2 of 3 Old 06-03-2007, 03:31 PM
CCrew
Just change the threaded rods for the links. Put the ones that come with it aside and fab shorter ones so that the arms are level with your current lift. When you upgrade switch rods.
-Roger
CCrew is offline
post #3 of 3 Old 06-03-2007, 03:36 PM Thread Starter
CopaTJ99
-Roger
Where do I get the threaded rods? Lowes or Home Depot? Any required stiffness grade? What size are the threads? Thanks.
Anthony
CopaTJ99 is offline
Currie 4" Suspension System w/Rear Anti-Rock MDC3 JK Wrangler Technical Forum 4 01-28-2010 07:10 PM
currie anti rock jeepwcrazy TJ Wrangler Technical Forum 4 08-26-2008 06:58 AM
what would you do? (RE 4.5" tri link, stock size tires, Currie Anti Rock) steelefx4 TJ Wrangler Technical Forum 6 01-02-2008 10:31 AM
anti rock w/4" lift TRUSSMAN TJ Wrangler Technical Forum 9 07-18-2007 12:12 PM
anti rock and 2" lift Nikos TJ Wrangler Technical Forum 4 07-10-2006 11:46 AM
