-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Currie Anti-Rock or discos on stock TJ? (http://www.jeepforum.com/forum/f9/currie-anti-rock-discos-stock-tj-192401/)
Jerry Bransford 09-12-2005 12:43 PM
It'd be an easy and inexpensive process to go buy 2' of 1/2x20 threaded rod and cut it to the correct length so an Antirock could be installed on an unlifted (or minimal lift) vehicle. Probably cost all of $3.00. :)
TJVigilante 09-12-2005 01:32 PM
Bah, save yourself alot of money and get a set of budget discos, and get the anti-rock, swaylok or the other disconnects later after you lift the rig, so you don't have to buy a whole new set. 10 bucks and you're golden, and it's just as fast as any 150 dollar disconnect set you can find.
lupinsea 09-12-2005 08:16 PM
The Anti-rock end link trick: custom machined center links.
When I ordered the Anti-rock I was a little hesitant about it but was assured by Jason at Redrock4x4 that it was a great piece of equipment. I'm glad I followed his advice because I absolutely love this piece of engineering. Sure, the Swayloc is tops but I'd mark this up right behind it. The only problem with the design is that Currie set it up for 4" lifted rigs and there's not enough adjustment for shorter TJs. To get it to fit requires some creativity.
Since I was installing the Anti-rock on a 2" lifted Tj I needed to shorten the threaded rods for the end links. Unfortunately Currie supplies rods for a 4" lifted Jeep and simply cutting them down to size wouldn't work. Here's the reason:
http://homepage.mac.com/jgreening/.P...FD01AE11D9.jpg
End links too close on a 2" BB lifted TJ
The rods supplied by Curried are only partially threaded. And to make the rods fit a 2" lifted TJ (and stock for that matter) you'd need to run the threads all the way to the center of the rod so they meet in the middle. Sounds simple enough, either get new threaded rod or use a die and thread it yourself.
Not so fast. There are left hand threads and right hand threads on the supplied rods. This makes it great for adjusting the link post-installation but a PITA if you want to add more threads. And I don't know of any all-thread rod that comes with half way threaded with both directions. But wait, there's more.
The end link rods have ROLLED threads . . . not cut threads. With rolled threads a rod of slightly smaller diameter is placed in a machine which has roller teeth that push the metal UP into the shape of the threads. So where you don't have any threads the rod necks down. In other words, you can't simply cut more threads into the rod with a die . . . there wouldn't be sufficient thread engagement.
What to do? Custom machined end link rods.
http://homepage.mac.com/jgreening/.P...6601AE11D9.jpg
Note custom machined link/bolt on top
When I talked to a machine shop they gave me this suggestion for reducing the machining costs. Go to a fastener store and get a bolt that's long enough with a thick shaft and cut threads at the end in propper pitch and diameter. Have the machine shop cut the nead off the bolt and then they have enough material to cut the left hand threads into the thick end of the bolt shaft. Some guys at a local machine shop did this for me at the tune of $25 per bolt (x 2) at the very last minute on the Friday right before I was heading out on a 3 day wheel'n trip on the other side of the state.
With the machined bolts/links in place the fit and alignment was great.
Sure, it was a bigger job to get the Anti-rock setup on my Tj than I figured but after it's all said and done I'm really glad I made this mod. As others have mentioned and as the warning states there is more body roll on-road. But it's not bad. The critical moment is the transition from going strait to entering a turn. Since the Anti-rock is a softer swaybar it takes a little extra lean until it starts really resisting the body roll. And until the TJ takes a set in the corner it may feel a little disconcerting to some in this momentary transition state.
By starting to turn in a little sooner and being smooth with the steering wheel you can all but negate the extra body roll. The idea is to gradually load up the Anti-rock rather than hit it all at once with a sharp turn. With this new driving technique I can confidently take corners 10-15 mph above the speed limit. Not that I do regularly but during some testing and some moment of hurry I have.
Around town the Anti-rock feels just fine. And on the highway I have no worries with the TJ cruizing at 80 mph. Back mountain roads are a-ok at the speed limit or even 5-10 mph over. Again, not that I'd recommend it but I've done it out of curiosity.
However, off-road is where this beastie really shines. You only give up 4% of potential flex but what you get in return is well worth it. The TJ body feels much more controlled and the pitch/roll very well balanced between the front and rear axles. And because of that balance, the Anti-rock help improve traction by equalizing the weight on the tires. Side-hill driving is also much aided by having a swaybar hooked up as opposed to being disco'd.
If you, or anyone else, wants more info on the installation of this device on a not-so-lifted Tj I have a a full write-up on my website here. In the end I'd fully recommend this, even to a stock Tj. Just be aware of what you're getting into. And keep the supplied rods from Currie if/when you want to go up later.
:thumbsup:
Dirty Backroads 09-12-2005 09:26 PM
Some very interesting and informative replies here. I really appreciate them all. :)
I've decided to go with a set of JKS Quicker Discos for now. Since my Jeep is driven mostly onroad I'm going to make onroad handling the priority right now and go with the discos to preserve the stock handling onroad while still getting some benefits offroad. While I'm new to Jeeps, I've modded other types of cars before and my experience is that it's better to take it slow and be cautious so I'm going to go that route. Perhaps I can get a ride in an AR-equipped TJ and see for myself how it handles both on and offroad.
I think the JKS Discos will definitely help on the trail and are a fairly small investment right now that have little downside. Once I get a feel for things and decide what it is I want to do with my rig regarding lift and tires I'll see about Anti Rock or Swayloc. In the meantime I am going to research some sort of air source for airing up as that's a good idea regardless of what I'm doing with the swaybar.
DLoweinc 09-12-2005 10:54 PM
great post lupinsea, very informative and I am sure it will help many people.
VanBCguy 07-07-2009 07:01 PM
Thanks!
Many thanks on a superb write-up! And your pics helped a lot too. I currently have a 03 TJ w/ no lift but am planning on going with a Skyjacker 4" soon. I want to stay with my 31.5" tires as I have 2 almost new sets of tires. One set of Goodyear Silent Armors and one set of BFG M/T's. When these two sets get used and old I'll look into going to a good set of 35's on new Crager soft 8's.
Anyhoo...one of the mods I was planning was a Currie Antirock and you've basically given me all the info. I've been looking for. In so many respects, you and I are the same in what we want from our Jeeps and what our future plans for it are.
Thanks lupinsea! :thumbsup:
Thanks lupinsea!
lupinsea 07-07-2009 09:06 PM
Wow. Old thread.
Thanks for the thanks.
One thing to note is that I've moved on from the Anti-rock to the SwayLOC and am MUCH happier. The Anti-rock did all it was supposed to and performs great offroad. But I like the dual-rate SwayLOC much better as it provides SIGNIFICANTLY better on-road control yet gives you the same offroad control as the Anti-rock. . . and all with the flip of a lever.
So before you pull the trigger on the Anti-rock, look into a true dual-rate swaybar. The SwayLOC is a great one. But if I were in your shoes now, I'd check to see when Saavy Offroad is coming out with their dual rate swaybar as the original inventor and developer of the idea is part owner of Saavy. Should be cool to see what they'll do, especially after their awesome aluminum gas tank skid.
Bottom line:
Anti-rock = great for a trail only rig
SwayLOC / Dual Rate Swaybar = great for a DD or street driven trail machine where you ALSO want on-road stability.
rubicon20032003 07-07-2009 09:16 PM
I ran a antirock on a 3 inch.i just bought grade 8 alltread to replace links.Worked great no problem
FloorPro 01-04-2015 10:56 PM
I know this thread is super old...
However I have to clarify that I did indeed install a antirock on my stock jeep. It can be done and really improves your wheeling by keeping the jeep stable and all four tires in contact with the trail.
I wheeled the same trail two weekends in a row with the only change deing the antirock and it did flawless.
The trick I used was to take a cutoff wheel and cut the L/R threaded sections from the center shank and combine the L with the L and R with R. There is enough length to use the locknuts on each side of the rod/ link end. The instructions satated the system was designed for a 4" lift and a recommended rod length of 10.5". So I subtracted 4" and came up with a rod length of 6.5".
It is a tad squirrilly on road but if you only wheel once a month you can always run in a closer hole, I am in the second to last, and move it the night before a run and change it after.
It improved the trail experience by smoothing out the trail and allowing the axle to actually move under my TJ instead of just jaring you around. According to speed on my gps I was running the same sections of trail about 3mph faster and never felt out of control.
BloodThirsty 02-08-2015 04:43 PM
I'm in the same boat. Just got a stock tj that will remain stock. My end links are going bad. So the question is how has the antirock done on stockers? Is it even with it?
MurdaJs 02-08-2015 06:28 PM
Originally Posted by lupinsea (Post 7540931)
Wow. Old thread.
Bottom line:
Ahem
26679cj5 02-08-2015 06:41 PM
I haven't noticed any stability issues at all with my anti-rock. I run it on the second to the loosest setting.
BloodThirsty 02-08-2015 06:41 PM
Originally Posted by MurdaJs (Post 28206233)
Ahem
That was posted six years ago. From my understanding lots of people jumped off the sway lock bandwagon.
Jerry Bransford 02-08-2015 06:52 PM
X2, though I moved mine from that second-loosest setting to the loosest setting years ago. Even with my Antirock at its loosest setting, my TJ handles fine for me driving through the tight twisty mountain roads towing my tent trailer. The probable reason being that I'm running good shocks with a lot of control (OME NItrochargers) and those who complain are probably running a soft shock.
The time now is 04:18 AM.
