Currie Adjustable Control Arms Question - JeepForum.com
post #1 of 7 Old 09-12-2009, 07:29 PM Thread Starter
alvinl
alvinl's Avatar
I have Currie adjustable upper control arms on the rear of my TJ. How much of the threads can be visible behind the jam nut before I have to worry about them failing? I don't want to adjust them out so much that they become weakened or anything.
"Only two things are infinite, the universe and human stupidity; and I'm not sure about the former." - Albert Einstein
alvinl is offline
post #2 of 7 Old 09-12-2009, 07:40 PM
Dogman
Dogman's Avatar
I've heard the general rule of 1.5x the shank diameter worth of exposed threads.
John 3:17
Dogman is offline
post #3 of 7 Old 09-12-2009, 08:11 PM Thread Starter
alvinl
alvinl's Avatar
I was thinking I was safe with no more than 1" to 1.5" of threads showing. I will measure the shaft diameter to verify in the morning, but I think they are 3/4". So I think I should be safe up to 1.5".
alvinl is offline
post #4 of 7 Old 09-12-2009, 08:16 PM
Roye77
2011 JK Wrangler
How long have you had the currie arms? And do you like them? Im only asking because mine should be here on monday
Roye77 is offline
post #5 of 7 Old 09-12-2009, 08:24 PM Thread Starter
alvinl
alvinl's Avatar
I've been running mine for about 6 months. They were a good purchase, I like them a lot.
alvinl is offline
post #6 of 7 Old 09-12-2009, 08:29 PM
Roye77
2011 JK Wrangler
Are you running all 8 arms or just the uppers? The kit I ordered is all 8 and Im a bit excited to get them installed and try em out.
Roye77 is offline
post #7 of 7 Old 09-12-2009, 08:33 PM Thread Starter
alvinl
alvinl's Avatar
I only have the uppers. I have fixed lowers from BDS.
alvinl is offline
currie adjustable arms too short or bad install? motobob TJ Wrangler Technical Forum 168 01-19-2016 10:35 PM
currie control arms question XlostJeepX TJ Wrangler Technical Forum 1 02-12-2010 12:15 PM
Anyone seen or used these? (Currie control arms) remery829 TJ Wrangler Technical Forum 5 12-28-2009 09:38 PM
Rokmen vs Currie Adjustable Control Arms illinijeep TJ Wrangler Technical Forum 14 01-15-2009 08:33 PM
Adjustable Control Arms QUESTION stevenwheels TJ Wrangler Technical Forum 1 12-23-2005 09:06 AM
