Currie 4" Lift Too Tall - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Currie 4" Lift Too Tall
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting SleevesJeep Grand Cherokee Grills
Unread 03-22-2015, 01:59 PM   #1
Line58
Line58's Avatar
I installed a Savvy/Currie 4" lift last weekend and ended up netting around 6" of lift (compressed spring measurements are 18" front 13" rear). Do the currie springs usually net that much height or could I have gotten the wrong springs? Between that and the 1.25" BL (needed for TT), my rigs looking a little goofy sitting on 33's.
AX5 to YJ AX15 Swap
Line58 is online now   Reply With Quote Quick reply to this message
Unread 03-22-2015, 02:08 PM   #2
jjvw
jjvw's Avatar
Do you have much in the way of armor, bumpers, etc (i.e. added weight) attached to the Jeep?
'03 Rubicon
jjvw is online now   Reply With Quote Quick reply to this message
Unread 03-22-2015, 02:14 PM   #3
Line58
Line58's Avatar
All I have id an aftermarket 60" rear bumper from TKH Fab, a TerraFlex TT, and a winch on the stock front bumper.
AX5 to YJ AX15 Swap
Unread 03-22-2015, 02:27 PM   #4
afusco1222
Currie springs are usually soft. You should double check the part numbers and make sure you got the right springs. Hopefully they settle some but I wouldn't expect 2 inches.
afusco1222 is offline   Reply With Quote Quick reply to this message
Unread 03-22-2015, 02:37 PM   #5
Line58
Line58's Avatar
Here is how its sitting. There is ~10.5" between the top of my rear tire and the lip of the fender flare.
AX5 to YJ AX15 Swap
Unread 03-22-2015, 02:48 PM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is online now   Reply With Quote Quick reply to this message
Unread 03-22-2015, 02:58 PM   #7
GringoLoco
I don't know how many similarities there is between their 3" and 4" springs, but my Currie 3" netted me exactly 3" in front and about 4" in the back. I chalked that up to a mix of soft top with gutted interior and having thicker tunes on my 8.8 that puts the bottom spring perches up another 5/8". I ended up leaving the Currie 3" in the front and tossing a pair of OME springs (2"ish depending on the jeep) in the back. In my case it made sense, yours is a bit more weird. If think wrong part number but do they even make a 6" spring? I was thinking they only had 3" and 4".
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote Quick reply to this message
Unread 03-22-2015, 03:01 PM   #8
26679cj5
wtf that thing is riding high lol.
26679cj5 is offline   Reply With Quote Quick reply to this message
Unread 03-22-2015, 03:02 PM   #9
TJDaveX
Tater Salad
TJDaveX's Avatar
^^I agree. Here's mine with a Savvy/Currie 3" and 1.25" BL for comparison.
Maybe they sent you 6" springs by mistake? With your TT, I am wondering how your rear driveshaft is not binding at droop. Mine is about maxed.
TJDaveX is offline   Reply With Quote Quick reply to this message
Unread 03-22-2015, 03:10 PM   #10
Line58
Line58's Avatar
Here is what the front passenger side looks like. The part number on the spring is CE-9132F, which according to Currie's website is for a 4" lift.
AX5 to YJ AX15 Swap
Unread 03-22-2015, 04:17 PM   #11
Tonellin
Something is wrong with those springs. Just installed currie 4" springs yesterday on a buddies rig with 33's and it looks nothing like your rig
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is online now   Reply With Quote Quick reply to this message
Unread 03-22-2015, 06:22 PM   #12
mcktiger
Mine has the same part # the front doesn't look bad something in the rear is wrong
2006 tj rubicon
mcktiger is offline   Reply With Quote Quick reply to this message
Unread 03-22-2015, 06:42 PM   #13
GringoLoco
They didn't send you 2 sets of front springs did they? Would front springs even fit in the back? Never really looked to see if they would go in.
Odd noises
Unread 03-22-2015, 06:51 PM   #14
Line58
Line58's Avatar
No, they sent me front and back springs. The rear lengths of 13" is only an inch over what the rear should have been, according to the chart in the FAQ.
AX5 to YJ AX15 Swap
Unread 03-22-2015, 06:52 PM   #15
DezertTJ
Phrasing
DezertTJ's Avatar
That lift looks like a lot, but add 35s and rubi flares and it's similar to mine with the same coils and 1.25" BL. Stubby front bumper w/ winch
06 LJ Rubicon: AZ Backcountry LJ Build
AZ TJ FOR SALE
DezertTJ is offline   Reply With Quote Quick reply to this message
