currectlync install with RE 3.5 long arm - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > currectlync install with RE 3.5 long arm
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-29-2015, 01:08 PM   #1
Taylortd
Long time lurker, I just couldn't find the info I needed.
Ok, so I just bought a 2006LJ rubicon a few weeks ago. Its my dd and I am trying to work all the bugs out as I go. My stock tie rod has a bend in it and I have a little shimmy around 55,so I bought a currie currectlync and ome steering stabilizer. The install instructions say not to use with a drop pitman but the RE lift came with one, my front track bar is not adjustable. I think I need to order a stock pa and adjustable track bar. If I do, I was thinking either metal cloak or savvy. My concern is it steers perfect, no major wobble, I want to make sure this is what I need to upgrade my tie rods. I hate to fix something that is not broken, on the other hand I would like to upgrade as I go for better ride/longevity. In summary, do I need to replace my pitman arm, do I need an adjustable front track bar, if I do, metal cloak or savvy for a dd.
Taylortd is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 01:39 PM   #2
Tonellin
You likely don't have any steering issues because you also have a dropped trackbar bracket. Used in conjunction with the dropped pitman arm it makes the draglink and tracbar angles parallel again.
The MC or savvy tracbar are both great, the savvy one requires more bumsptop to run (2"?) as opposed to the MC bar not needing any additional bump
My advice would be swap to stock pitman arm, remove TB bracket and get the MC TB. However, if you are not experiencing any steering woes outside of the tierod being bent and likely failing soon because it looks OEM you don't necessarily need to swap anything.
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 03:38 PM   #3
sduncan
sduncan's Avatar
Your tie rod is bent because it hit the TB drop bracket when the suspension compressed. The RE bar is only slightly stronger than a wet noodle and the drop bracket can go away with a better TB.
Your best bet is the following...Order a Metal Cloak track bar, the Currie or ZJ steering, and an OEM pitman arm.
If trying to do it cheaply, then the ZJ steering, the MC bar and a Crown pitman arm will be about $375-400 total plus shipping. You'll be surprised at how much better it will feel..
'98 TJ, 5.7 HEMI, 545RFE, G2 33 spl. D44, HP D30,ARBs,4.10s, RE 4.5 LA,Savvy 1.25 BL,35in MTRs w/Pro Comp 15x10 alloys, Warn 9.5 cti w/Amsteel rope, Gen Rite G3 Alumium front fenders and rear flares, Premier Power welder 195 amp,Savvy Rockers,Prothane bumps,LED tail lites, Rampage top
Link to my Hemi build thread http://www.jeepforum.com/forum/f9/so...rsion-1277803/
YouTube video..http://www.youtube.com/watch?v=iaDRq...&feature=g-upl
sduncan is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 04:43 PM   #4
Taylortd
Great info! Exactly what I was looking for. I don't mind paying the extra money now to save myself problems down the road. With that being said, since I have the currie steering I'll order the mc tb and a crown pa. Thanks for the advice!
Unread 04-29-2015, 05:43 PM   #5
sduncan
sduncan's Avatar
You bet..I know what you are dealing with because I had the same parts..
Unread 04-29-2015, 10:23 PM   #6
Taylortd
Before I pull it all apart.... Is the stock track bar mount inside the extension? Or was it cut out/removed ?
Unread 04-30-2015, 12:25 AM   #7
mudb8
want it rite or rite now?
mudb8's Avatar
The re drop bracket bolts to it and the frame.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
