crush sleeve eliminator? - JeepForum.com
post #1 of 11 Old 02-23-2009, 11:39 AM Thread Starter
00TJ
Anybody know if they make these for the d30/35? If not will any of the other axle sized ones fit(8.25, 8.8, etc)? I'm doing a gear swap later this week and was hoping to not have to deal with crush sleeves.
thanks
2000 Tj 4" Full Traction, BL, MML Bilstein shocks 35 12.5 X-terrains D30/S35 w/4.88's Highrock bumper
1982 CJ7 SBC 350 Full Resto(under construction)
1946 CJ2A Full Resto(under constrution)
00TJ is offline
post #2 of 11 Old 02-23-2009, 12:49 PM
geauxturbo
geauxturbo's Avatar
I don't ever remember seeing one for the 30/35. An 8.8 etc will be much too large in diameter and probably not the correct depth either. Not to say there isn't one, give National Drivetrain or Randy's Ring and pinion a call...usually they can answer a question like that pretty quick.
'97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2
geauxturbo is offline
post #3 of 11 Old 02-23-2009, 01:07 PM
bnine
Last time I check there was not. You can get some tubing and have machined down to work.
Take some already crushed sleeves and use them as a reference. Knock 20 thou off the crushed length and go from there.
For shims you can use YJ D30 pinion shims. Those ones didnt use crush sleeve.
bnine is offline
post #4 of 11 Old 02-23-2009, 05:57 PM Thread Starter
00TJ
what type of tubing should I use? something like 1/4 wall dom? or something stronger? thanks for the ideas.
00TJ is offline
post #5 of 11 Old 02-23-2009, 07:40 PM
bnine
Thinner. Same as the crush sleeve, which is right around 60 wall.
bnine is offline
post #6 of 11 Old 02-24-2009, 06:31 AM Thread Starter
00TJ
ok, thanks bnine. I'll let you know how it goes.
00TJ is offline
post #7 of 11 Old 02-24-2009, 07:17 AM
RLD831
RLD831's Avatar
Why get rid of the crush sleeve? To me that was one of the easiest parts of the regear. I found it much easier than using shims as it is a one size fits all part that you tighten until the numbers are right. I'm not questioning you as much, just wondering what the benefit is.
RLD831 is offline
post #8 of 11 Old 02-24-2009, 10:26 AM Thread Starter
00TJ
RLD, it seems as though its easier to get the pinion shimed more accurately with the solid spacer. If the crush sleeve is over tightened you need a new one, it takes ALOT of torque to crush the sleeve, not only that but its easier to change the pinion seal if need be. I know you can change the seal with the crush sleeve, but your SUPPOSE to use a new sleeve(with requires you to remove the carrier). eventhough people have found a way around it. there could be more pros and cons, but thats all I could think of. If anyone else has any pros or cons, I'm all ears.
Thanks
00TJ is offline
post #9 of 11 Old 03-24-2013, 04:04 PM
shaban
Looked for it all over ebay and google. couldn't find it. Ended up ordering from some local machine shop guy for $60.
And got them shims from some random Ebay guy.
Works fine!
shaban is offline
post #10 of 11 Old 03-24-2013, 04:10 PM
shaban
More photos
shaban is offline
post #11 of 11 Old 03-24-2013, 04:14 PM
freeskier93
If you ever have to replace your pinion seal or yoke you will be very thankful for a spacer. Simply remove nut, replace whatever, torque back to spec.
IMO the crush sleeve was the worse part of the regear. I even bought an eliminator kit for my 8.8 but on the final install I put the shims in wrong and messed them forcing me to use a crush sleeve. Over tightened the one that originally came in my install kit and spent a whole day trying to find another one locally.
freeskier93 is offline
Dana 30 crush sleeve bmxrules39 TJ Wrangler Technical Forum 1 11-26-2009 09:46 PM
8.8 Crush Sleeve cj3bandtj TJ Wrangler Technical Forum 16 08-24-2009 11:19 PM
crush sleeve dduyj YJ Wrangler Technical Forum 1 09-14-2008 03:43 PM
Crush Sleeve MDOC111 TJ Wrangler Technical Forum 1 08-16-2008 08:14 AM
Replacing the d35 crush sleeve? TJforlife TJ Wrangler Technical Forum 6 02-22-2007 02:03 PM
