Cruise Control/Air conditioning vaccum hose locations? - JeepForum.com
post #1 of 5 Old 08-24-2007, 07:46 PM Thread Starter
rubicon4x4
rubicon4x4's Avatar
Hey, I need help from those with both cruise control and air conditioning installed. I have a 2004 Wrangler SE that came with A/C and I installed mopar cruise control into it recently. Problem is, I used the vacuum hose T-connection on the passenger side near the battery for the vacuum hose line from the cruise control servo and just left the other hose hanging unconnected....which i discovered controls the vents for the A/C.
My question is...I traced the vacuum line towards the driver side along the firewall and found a possible t-connection for the vacuum line near the center but I'm not sure. It appears to be an in-line T-connection for the cc servo vacuum hose but I want to be 100 % sure and not have an "ooops" Thanks guys!
Paul
2004 Black Wrangler SE 4cyl manual.
"Now, we must all fear evil men, but there is another kind of evil, which we must fear most, and that is, the indifference of good men."
rubicon4x4 is offline
post #2 of 5 Old 08-25-2007, 01:19 AM
huntoon
ill check as i have an 04 rubi with both of those ill get back to you
huntoon is offline
post #3 of 5 Old 08-25-2007, 01:22 AM
TexanTJ
2014 JK Wrangler
i know that theres a 'vacume canister" (dont know if thats the right term) underneath the battery on my 05. When i installed my phantom fenders, i had to relocate it. Without it connected to the intake manifold, the cruise wouldnt work and niether would the ac.
2014 JKU Sport - Wife's Mall Crawler on 35s. Badlands Winch, 2" Coil Spacers, 1" PA BL
1999 F250 7.3 - 290K Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline
post #4 of 5 Old 08-25-2007, 10:38 AM
Texan4life
I knocked a hose loose and my AC would only work as a defroster, no matter what I selected. The hose connected on the top of the engine on the driver's side, near the throttle body. Hope that helps.
Texan4life is offline
post #5 of 5 Old 08-27-2007, 01:15 PM
huntoon
my cc hooks up at a T right off of the intake on the drivers side and then that line goes to the firewall and to the pass side
huntoon is offline
YJ breather hose locations?? YJake YJ Wrangler Technical Forum 18 05-20-2016 05:16 PM
Help with Cruise Control on TJ´00 Alberto4x4 TJ Wrangler Technical Forum 16 11-13-2009 11:02 AM
Vacuum hose locations? WalrusPaul YJ Wrangler Technical Forum 9 09-17-2009 06:54 AM
Where does this Vaccum hose go on my 2.5L? flyinbrad YJ Wrangler Technical Forum 9 09-16-2008 06:56 PM
O.K. So, I found the vaccum leak...now I can't find the hose... JeepinYahoo TJ Wrangler Technical Forum 11 04-04-2007 07:01 PM
