Crossover steering - uptravel limiting factor? - JeepForum.com
post #1 of 11 Old 01-16-2013, 09:20 AM Thread Starter
Ben
Any of you guys running full crossover, what's the limiting factor of your uptravel?
Drag link contact with frame?
Tie rod contact with pitman arm?
Other?
Sorry to have 2 threads going (link to other one), but I figure this is a specific question, and there's more traffic here in TJ Technical.
Ben is offline
post #2 of 11 Old 01-16-2013, 02:19 PM
Robert J. yates
My frame is notched to accommodate the drag link... raised trackbar gets pretty close too.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #3 of 11 Old 01-16-2013, 02:42 PM
dcope17
http://www.jeepforum.com/forum/f9/no...rsion-1296085/
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #4 of 11 Old 01-16-2013, 03:16 PM Thread Starter
Ben
Man I wish I had seen that before I started.
What pitman arm is that? You mention bending it, so just a stock one flattened?
No issues with the tie rod hitting it with that much drag link clearance?
Ben is offline
post #5 of 11 Old 01-16-2013, 04:04 PM
dcope17
Yep, stock pitman arm. With the axle on both bumpstops, the tie rod, drag link and trackbar. All clear each other by about 1/2 inch.
Things that are not adjustable... tie rod at both ends, drag link at the knuckle.
Stuff the axle then adjust the pitman arm to keep the drag link from hitting the TR and also miss the radiator and steering gear lines... once that is set, snake a track bar through there ( parallel and same length as draglink ) do this last since you can adjust either end to make it fit.
dcope17 is offline
post #6 of 11 Old 01-16-2013, 06:04 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Other?
My WJ conversion didn't require any frame modifications...
Knuckelhead is offline
post #7 of 11 Old 01-16-2013, 06:35 PM Thread Starter
Ben
Neither would mine, with the right amount of hockey pucks.
Have you kept the stock frame side track bar bracket? I would guess you have enough bump stop to keep that out of the diff cover?
What's first to hit on yours, as you approach full bump?
Ben is offline
post #8 of 11 Old 01-16-2013, 06:39 PM
dcope17
Now... lower the drivers side of the axle to its lower limit while leaving the passenger side on the bumpstop... then turn full right.
After that, then you can say you don't need to modify the frame...
dcope17 is offline
post #9 of 11 Old 01-16-2013, 08:25 PM
Knuckelhead
AFSOC Retired
I don't use hockey pucks.
Yes.
Yep.
Nothing that has been a problem, the extended bump stop I would say....
post #10 of 11 Old 01-17-2013, 08:59 AM
mcannon111
I'm running a waggy 44 with a flat top knuckle and high steer arm on the passenger side. I still need to notch my frame so i can get full up travel. Some people say you can flip the drag link to the bottom side of the high steer arm, but i'll probably just notch the frame to keep the drag link completely flat. But other that that its fine. Everything under there gets really close, but it clears. If you are running heims, i'd suggest putting no misalignment spacers on the drag link end because there should be enough misalignment off the heim at the knuckle end.
If you are planning on running it, i also suggest to not have anything to do with the stock track bar frame mount, Cut that thing off and start over new with an outside frame bracket and some heims.
here is a picture of mine drooped pretty far out when i was setting everything up.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #11 of 11 Old 01-18-2013, 08:45 AM Thread Starter
Ben
Yeah, tried this last night. That's gonna be the problem.
I tried that, there might be room with flat top 44 knuckels, but not with WJs. Thanks though.
Yep. That's gone.
Ben is offline
