Crossmember / transmission mount advise please - JeepForum.com
post #1 of 13 Old 01-22-2013, 10:44 AM Thread Starter
SC-TJ
I wanted to install a Novak shifter and paint my crossmember .... Removed the crossmember (without supporting the transmission ) and saw the original transmission mount had completely dry-rotted. I ordered an after market transmission mount. Time lapse 1 month till I had time to put the jeep back together. As I put the crossmember back in place, with the transmission mount bolts passing through the crossmember - the entire crossmember now does not line up with the holes in the frame. It is off about an inch toward the passenger side. I assume 1 of 2 things are causing this: either the transmission shifted over an inch when it was not being supported, or the bolt positions for the new transmission mount are not the same as the original. Actually, it is hard for me to believe either of the 2 are possible, but I don't see any other reason for this misalignment.
The transmission mount is securely bolted to the underside of the t/c..... Would it be ok to cut off the transmission mount studs that pass through the crossmember? .... Just so I can get the crossmember to align with the frame?
Any input would be appreciated.
SC-TJ is offline
post #2 of 13 Old 01-22-2013, 10:48 AM
mdm
Farm Wheeler
When the transmission dropped down it didn't drop straight down. Move the transmission back to where everything lines up. Don't cut anything.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 13 Old 01-22-2013, 10:48 AM Thread Starter
SC-TJ
These are the 4 bolts I have considered cutting off. They don't seem to serve any purpose.
SC-TJ is offline
post #4 of 13 Old 01-22-2013, 10:53 AM
EGLESCT
Those bolts actually serve a very important purpose. They bolt the transmission mount to the transmission skid-plate. With out those attached, your transmission will bounce up and down every bump you hit
2003 TJ 4.0L 5speed 30/35
"Courage is being scared to death... and saddling up anyway" - John Wayne
EGLESCT is offline
post #5 of 13 Old 01-22-2013, 10:54 AM
Wordgie
They do serve a purpose. They hold the rubber mount to skid plate.
The plate supports the transmission and T-Case, so when it went unsupported, gravity took over. That amount of time can cause more issues.
Wordgie is offline
post #6 of 13 Old 01-22-2013, 10:57 AM Thread Starter
SC-TJ
I always hesitate to have to "force" something back into place......
SC-TJ is offline
post #7 of 13 Old 01-22-2013, 11:03 AM
mdm
Farm Wheeler
You could ask it nicely to move over. When that doesn't work, get a bar or 2x4 and ask it again.
mdm is offline
post #8 of 13 Old 01-22-2013, 11:15 AM
CharlieHo
CharlieHo is offline
post #9 of 13 Old 01-22-2013, 11:21 AM
oalali
oalali is offline
post #10 of 13 Old 01-22-2013, 11:31 AM
ssquier92
Then you should also have hesitated to let all the weight of the TC transmission and motor hanging back to all be relying on your motor mounts and probably some wiring harnesses for that time. Move it back over, do not cut anything.
2002 TJ 3.25" RC lift, 1.25 BL, MML, 33X12.50 Goodyear MTR w/ Kevlar, adjustable front trac bar, cut stock bumper, poison hood louver, B&M short shifter, chromoly rear axle shafts in the d44 4.88s Grizzly locker, Aussie locker up front in d30,10,500lb winch w/ synthetic rope, antirock, jcr sliders, savvy arms
Work harder, thousands of people on welfare are counting on you.
ssquier92 is offline
post #11 of 13 Old 01-22-2013, 11:32 AM
Randonexplosion
Randonexplosion's Avatar
New sig
Randonexplosion is online now
post #12 of 13 Old 01-22-2013, 09:05 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You let 400 lbs of transmission, bellhousing, and t-case force it out of place and temporarily deform the motor mounts, it won't hurt a thing to sweet talk it back into place with a bit of force.
The trick to that is jack the skid up and line it up on the 4 small studs in the mount, start the nuts on them and then work the whole mess into place on the frame bolts.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #13 of 13 Old 01-23-2013, 11:24 AM Thread Starter
SC-TJ
Everything is back together and working good. Piece of cake.
SC-TJ is offline
