Crazy shake from the road - JeepForum.com
post #1 of 5 Old 02-02-2011, 12:30 PM Thread Starter
hardcoreskimmer
O.k. so I have looked this up in the Forum and I have a few ideas what it could be but I figured I would start a thread anyways. The main reason why I started a new thread because the shake I get is enough to shake a martini. It is crazy, I was driving on I-4 a couple weeks ago and I switched lanes going about 70 mph and I think there was a bump and the whole jeep started shaking violently, including the steering wheel. Pulled over keep shaking until I came to a complete stop, I got out looked all around, didn't see anything out of place or anything like that. So got back in kept driving, also scared me enough to put on my seatbelt. So a week later I was driving I was going about 50mph hit a bump same thing happen, next day same spot, same speed, happen again. Then yesterday it happen once again except this time my buddy was driving behind me and he said my driver side rear wheel was jerking around but he didnt thing to look at the passenger side rear wheel. I checked the outside of the axle everything looks in order, with the exception of my pinion bearing going, any ideas what it could be? If you got any questions I will try to answer them. Need to fix asap its my dd
99 TJ 4 banger 2.5" skyjacker 31" buckshots
hardcoreskimmer is offline
post #2 of 5 Old 02-02-2011, 01:11 PM
RockMonster
its death wobble or the start there of, search it.. it plagues us all... haha check the track bar (axle side) for ANY play) unfortunately it cant be traced back to one thing in allot of cases.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #3 of 5 Old 02-02-2011, 07:09 PM Thread Starter
hardcoreskimmer
well yeah its death wobble, that's obvious but i was trying to narrow it down a bit, trac bar is fine, also i believe most people get death wobble from the front, but mine is in the rear.
so it does it only 50mph and above and it needs a bump to jump start it. any thoughts?
post #4 of 5 Old 02-02-2011, 08:27 PM
wushaw
Rockin jeep
wushaw's Avatar
Loose or worn out components. Your gonna have to get under there and check everything...ya can't just look at it you gotta grab, shake, and move things around to find the loose/worn components.
wushaw is offline
post #5 of 5 Old 02-02-2011, 09:01 PM Thread Starter
hardcoreskimmer
yep yep did that with everything that connects to the rear axle and checked all the welds as well, and everything looked fine, could it be an axle bearing perhaps?
Does anyone else's steering wheel shake like crazy when its windy ? 95yj0645 YJ Wrangler Technical Forum 1 11-06-2010 12:42 AM
bad shake cmilks TJ Wrangler Technical Forum 1 09-01-2010 07:30 PM
Shake at 55 mph? drottie TJ Wrangler Technical Forum 23 10-28-2009 08:48 PM
Advice on increasing on-road ride quality without sacrificing off road Lord_Xcalibur Wrangler General Discussion 15 12-15-2008 07:41 PM
Crazy snorkel idea! Too crazy? Bryan_16 TJ Wrangler Technical Forum 13 11-06-2002 09:04 AM
