crazy (death?) wobble while braking - JeepForum.com
post #1 of 8 Old 04-19-2007, 10:00 AM Thread Starter
badoosh27
badoosh27's Avatar
sometimes when i am slowing down, usually if i slow down really quickly, my steering wheel goes crazy. it doesnt happen all the time, but when it does it's a little un-nerving. i just had the tires balanced and that didnt help, so i think if i get it aligned it'll get better. any ideas?
also, i dont know if this is death wobble so let me know if it is.
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #2 of 8 Old 04-19-2007, 10:05 AM
Blake Rust
Blake Rust's Avatar
I have the same problem.
mine occasionally does the same thing but mine also does while cruising on the highway if I hit a bump just the right way.
Blake Rust is offline
post #3 of 8 Old 04-19-2007, 10:42 AM
$lick
warped rotors
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline
post #4 of 8 Old 04-19-2007, 10:43 AM
paroxysym
2007 WK
Originally Posted by $lick
warped rotors
death wobble occurs while accellerating- not braking.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #5 of 8 Old 04-19-2007, 11:04 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep, just sounds like you have some severely warped front brake rotors... not Death Wobble.
Gone on vacation until August 25.
Jerry Bransford is offline
post #6 of 8 Old 04-19-2007, 11:35 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's not death wobble, but a very close cousin. It typically happens in a mild turn like exiting an offramp and hitting the brakes between 47 to 53 MPH and the steering wheel starts oscillating fairly violently, but controllable when you get below 45 miles per hour.
If that describes your symptoms pretty accurately, you need new front rotors and pads.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #7 of 8 Old 04-19-2007, 01:48 PM
BradG
When I first bought mine, I had something going on like that. Hit the brakes on the interstate pretty hard and had this crazy wobble in the front end. Scared the poopy out of me. I had the tires replaced that weekend, though, including balancing and a front end alignment and the problem went away.
2003 TJ X Silver | 31x10.50x15 BFG A/Ts | 10k front tow hooks, factory rear tow hook | 2" coil spacers | Cobra 19 with RatShack 102" stainless whip on an Arizona RockyRoad tire carrier mount | Kilby Steering Box Skid | AtoZ Fabrication Rock Sliders | Olympic Slider Rear Bumper w Receiver | Skid Row Engine/Oil/Tranny skid (still sitting in my living room)
BradG is offline
post #8 of 8 Old 04-19-2007, 03:00 PM
Dogman
Dogman's Avatar
Check your trackbar bolts and make sure they're torqued. I have slightly warped rotors and a loose trackbar on the axle side created that exact wobble. Tightened up the trackbar and I'm back to slightly warped rotors which I need to fix
John 3:17
Dogman is offline
Solution to steering wobble and death wobble...need help Sparty TJ Wrangler Technical Forum 5 10-01-2010 07:25 AM
new budget boost CRAZY death wobble ErnieG TJ Wrangler Technical Forum 11 03-30-2009 07:08 AM
Death Wobble, When Braking at Speeds over 50MPH tdog522 TJ Wrangler Technical Forum 2 03-25-2008 04:13 PM
Death Wobble during braking? chaz7979 TJ Wrangler Technical Forum 19 08-10-2007 06:42 AM
REBB Steering Wheel Straight, No Vibes, No Death Wobble <--Am I Crazy? 04JeepTJ TJ Wrangler Technical Forum 20 08-09-2004 07:47 PM
