Crankshaft Position Sensor or Camshaft Position Sensor? - Page 2 - JeepForum.com
post #16 of 20 Old 01-20-2011, 11:31 AM
pcoplin
pcoplin's Avatar
Originally Posted by SierraNev View Post
Hey ya'll I am having intermittent issues with my Jeep stalling while driving after a few minutes or at idle speed and after warm up. The codes for pcm not getting signal from cps/cpk "crankshaft positioning sensor" came up. So now that I've gotten that far how the heck do you get to the bugger, take the tire and inner tire panel off or drop the trany? I got a chilten with microscopic pic's and a fellow said I would need a pully puller, I think I can handle it with a lil direction. How bout it fellow Jeepers, a brotha could use some help, its our only car right now. 99 Jeep Grand Cherokee Limited 4.7L
The 5.9 in my TJ did this, sometimes it would miss for a bit, sometimes stall. ALways just after warm-up, 8-10 minutes of run time. Crank Sensor fixed it.
pcoplin is offline
post #17 of 20 Old 12-12-2011, 07:14 PM
PAwranglers28
yeah, definitly the crank sensor. Just found out mine was bad on my wrangler. depending on where you order them from they range in price from 60-100 bucks.
PAwranglers28 is offline
post #18 of 20 Old 01-08-2015, 02:07 PM
supertim996
I too have gone through this and now am going through it again 2 yrs later. I have an 05 wrangler X 6 spd, 4.0L. After replacing both sensors ( crank/ cam), as well as gear on distributer. I had ECM reflashed at the dealer, about $100.00. No problems until now. Engine would occasionally stumble at idle, then popped a p0016 code. Replaced both sensors again, erased codes and all seemed fine and ckps code popped up. Will try fixes on here to see if it helps
supertim996 is offline
post #19 of 20 Old 01-09-2015, 12:10 AM
oakmckinley
FWIW
When my crank sensor went it WOULDNT buck or hesitate. It would just turn off, like someone turned off the key. It did the same on 2 different vehicles.
So the bucking, hesitation and almost stalling but still running makes me think something else is the problem.
Also those sensors can be bad right out of the box. I put a brand new mopar crank sensor in and it went bad in a few days.
Good luck
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #20 of 20 Old 11-28-2015, 05:27 PM
rrose
Hey guys 99TJ 4.0 that just decided not to start one day. Turns over strong, but would start. Immediately check for spark by pulling plug wire and no spark. Went to CPS and tested with multimeter and checked out ok. Since CPS was ok, I then tested ignition coil and no spark with plug manually put in so I replaced ignition coil. Still no spark at coil and obviously still no start. Any ideas? BTW, had tune up kit so replaced the following while it was down and in the garage (plugs, wires, distributor cap, rotor button, valve cover gasket).
rrose is offline
Check engine light due to camshaft/crankshaft position sensor caseyLA TJ Wrangler Technical Forum 7 07-26-2010 07:53 PM
Camshaft Position Sensor? 04TJSport TJ Wrangler Technical Forum 3 07-10-2009 02:03 AM
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 04:07 PM
Camshaft Position Sensor? Benny2Times TJ Wrangler Technical Forum 3 10-02-2008 03:27 PM
Crankshaft and Camshaft Position Sensor westbrooklawn TJ Wrangler Technical Forum 4 01-29-2004 10:15 AM
