Crankshaft Position Sensor or Camshaft Position Sensor? - JeepForum.com
post #1 of 21 Old 04-26-2005, 09:57 AM Thread Starter
TennesseeTJ
Hey all...
My 98 TJ 4.0 with manual trans has been experiencing random loss of power for a year. It sputters, rpms plummet, it sometimes catches itself before it completely dies, other times it shuts down totally. Occasionally it is difficult to restart. This occurs totally randomly, on accelleration, idle, highway speed, whenever.
Yesterday, it FINALLY gave me a diagnostic code:
P1391 - Camshaft Or Crankshaft Position Sensor Intermittent Loss
From the symptoms, that sounds corrent. But which should I replace? Is one or the other known to be trouble on these Jeeps? Any insight would be greatly appreciated!
-Erik
TennesseeTJ is offline
post #2 of 21 Old 04-26-2005, 09:59 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The crankshaft position sensor is noted for more problems than the camshaft position sensor is.
Jerry Bransford is offline
post #3 of 21 Old 04-26-2005, 10:27 AM
Stu Olson
Stu Olson's Avatar
x2 for sure
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #4 of 21 Old 04-26-2005, 11:02 AM
joeyt17
My crankshaft position sensor went out and caused the same problems as you are currently getting. I didn't even get an engine code for it until several days after all the problems started occuring.
changed it out and no problems since
joeyt17 is offline
post #5 of 21 Old 10-15-2005, 06:12 AM
James D. McGinn
I changed both the camshaft and crankshaft position sensors on my 98 TJ with 2.5 and 5 speed, and the cel is still on, and it still reads code 1391, even though i have zeroed out the codes several times; however, the engine does run well. Anyone give me any ideas? thank you.
James D. McGinn is offline
post #6 of 21 Old 12-10-2005, 08:31 PM
JV96XJ
I have the same situation on my '96 XJ. Replaced both sensors, and the CEL still comes on....Have you resolved your probelm?
1996 Jeep Cherokee SE - Dark Blue
190-hp 4.0L OHV I-6-cyl w/4-spd autoCommand-Trac 4wd
2005 Nissan 350Z Performance- Silverstone
287-hp VQ35DE -3.5L DOHC 24-valve V6 w/6 spd manual
JV96XJ is offline
post #7 of 21 Old 12-11-2005, 06:58 AM
Scott_98TJ
Well they both talk to the PCM so that's an obvious common link. They also share some wiring on the sensor return and feed from the ignition cicuits. With a wiring diagram you could check all the connections fairly easily.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
post #8 of 21 Old 12-11-2005, 07:30 AM
LadyJeep
LadyJeep's Avatar
I had the same problem with my 98 auto 4.0L. It finally did die (wouldn't turn over) out in the desert. Ended up being the CPS.
Maggie
98 Sahara, 4.5" RE longarm and more.
To see more about my jeep go
LadyJeep is offline
post #9 of 21 Old 12-11-2005, 09:18 AM
al666
I have the same code on my jeep, been trying to figure it out for 4 months replacing the sensors didnt help could be wireing but im just bringing it to jeep to fix good luck though
al666 is offline
post #10 of 21 Old 12-11-2005, 09:33 AM
MCanavan
I had the same problem and replaced the crankshaft sensor but still no luck. I took it to a mechanic and it turns out that it was the oxygen sensor (wasn't giving out a code though).
MCanavan is offline
post #11 of 21 Old 12-11-2005, 01:12 PM
98JEEPTJ
2005 WK
I was told by one of the mechanics that the engine wouldn't run at all if the Drive shaft sensor or the crank position sensor wasn't working. That they don't partially work they work or they don't...They both sense a magnetic field disruption which is sent to the computer to tell it where the cam is or the drive shaft. if there is no disruption at all (failed sensor) then the computer wont start the firing sequence of the injectors...
Anybody absolutely know for sure???
OUT WITH THE OLD R.I.P. 98 TJ Sport 4" Procomp lift/adjustable lower control arms and track bar **** Cepek FCII 33x12.50x15/**** Cepek DC-1 wheels
IN WITH THE NEW 05 WK LIMITED EDITION 5.7L
98JEEPTJ is offline
post #12 of 21 Old 12-21-2005, 04:43 AM
Scott_98TJ
As a sensor starts going bad, or the connection has high resistance, it can and will cause flaky problems. If it randomly looses signal, you will get stalling, bucking, hesitations etc. rather than and on/off scenario that you get with a good or failed sensor. In a perfect world he's right, but how often does that happen with Jeeps?
post #13 of 21 Old 04-16-2010, 10:39 PM
SierraNev
Hey ya'll I am having intermittent issues with my Jeep stalling while driving after a few minutes or at idle speed and after warm up. The codes for pcm not getting signal from cps/cpk "crankshaft positioning sensor" came up. So now that I've gotten that far how the heck do you get to the bugger, take the tire and inner tire panel off or drop the trany? I got a chilten with microscopic pic's and a fellow said I would need a pully puller, I think I can handle it with a lil direction. How bout it fellow Jeepers, a brotha could use some help, its our only car right now. 99 Jeep Grand Cherokee Limited 4.7L
SierraNev is offline
post #14 of 21 Old 01-20-2011, 11:12 AM
nojeeps
The crank sensor is on the lower passenger side of the engine block under the vehicle. The cam sensor is at the front of the passenger cylinder head on the bottom of the head itself.
nojeeps is offline
post #15 of 21 Old 01-20-2011, 11:20 AM
mdm
Farm Wheeler
This is a TJ forum which deals mostly with 2.5 and 4.0L engines.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
Check engine light due to camshaft/crankshaft position sensor caseyLA TJ Wrangler Technical Forum 7 07-26-2010 07:53 PM
Camshaft Position Sensor? 04TJSport TJ Wrangler Technical Forum 3 07-10-2009 02:03 AM
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 04:07 PM
Camshaft Position Sensor? Benny2Times TJ Wrangler Technical Forum 3 10-02-2008 03:27 PM
Crankshaft and Camshaft Position Sensor westbrooklawn TJ Wrangler Technical Forum 4 01-29-2004 10:15 AM
