Crankshaft pos sensor - JeepForum.com
post #1 of 4 Old 09-18-2010, 05:26 PM Thread Starter
MattSkp
Hello , a quick question for those who know.Can i use a cps from a 1998 tj on a 2002.Its a 2.5 on both models.I am asking this question because i have the part from a 98 and want to test before buying a 99$ sensor.
I get the code P320 .
Thank you.
MattSkp is offline
post #2 of 4 Old 09-18-2010, 05:30 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Fill in your profile! Is it an automatic?That makes a difference with a paper gasket.
GOLENJEEPTJ is offline
post #3 of 4 Old 09-18-2010, 05:44 PM
BWFBezerk
Go to Autozone or Advanced Auto website, look up part for both vehicles, part number match?
2004 TJ SE 2.4L 5-speed. 2.5" Rough Country Lift, 1.25" Rough Country BL, Rough Country Stinger, Rough Country Rocker Rails, 9,500LB Vortex Winch ($200 off eBay), 4' FireStik, CB, Dana 30/35 4.10's, front Aussie Locker. 33x12.50x15 Dakota A/T on 15" Canyons painted black, 1.5" wheel spacers. Remote Start. MCE Flatty Fenders. All work done by me, with some help from my friends.
Videos:
Pics:
Xbox: BWFBezerk
BWFBezerk is offline
post #4 of 4 Old 09-18-2010, 06:04 PM Thread Starter
MattSkp
Its a manual 2.5l ,2002.The other sensor looks the same, its just the numbers on it are different.I check on sites it says 199.. to 2001.I am just wondering if i can test if this is my problem or if i should look elswhere.Might be the fuel pump/filter.
MattSkp is offline
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 04:07 PM
crankshaft pos sensor JSBlu974X4 TJ Wrangler Technical Forum 28 08-27-2007 09:39 PM
crankshaft postion sensor? youngjeeper11 TJ Wrangler Technical Forum 5 07-28-2006 10:01 PM
Crankshaft Position Sensor mance YJ Wrangler Technical Forum 6 03-09-2005 08:10 PM
crankshaft position sensor lexington TJ Wrangler Technical Forum 11 11-15-2002 08:18 AM
