Crankcase valve leak - JeepForum.com
post #1 of 8 Old 07-20-2010, 08:51 PM Thread Starter
cubbieblue
I noticed today that there was an accumulation of oil around the crankcase valve (or whatever you wanna call it) towards the front of the engine. When I wiggled it around I could see a little oil kind of seperate in between the lips of it.
Here is a pic of what i am talking about:
Is this normal? If not how do I fix it and what has caused it?
cubbieblue is offline
post #2 of 8 Old 07-20-2010, 09:00 PM
wushaw
Rockin jeep
wushaw's Avatar
Normal.
wushaw is offline
post #3 of 8 Old 07-20-2010, 09:16 PM
fish4life
i have the same issue, except mine is starting to throw out quite a bit of oil. I was told to grab the piece and pull it out of the valve cover ... then put a new one in. However, it simply won't go. I could use a screwdriver or something, but want to confirm it really is supposed to just pop out of there???
fish4life is offline
post #4 of 8 Old 07-20-2010, 09:19 PM Thread Starter
cubbieblue
Also what is the proper name of the part?
post #5 of 8 Old 07-20-2010, 09:38 PM
buddyfilek
Those are for crankcase gas ventilation. A little oil is okay but not too much. Pull the hose off the elbow and see if it is clean inside. You can also pull the elbow out with a good tug.
buddyfilek is offline
post #6 of 8 Old 07-20-2010, 09:40 PM Thread Starter
cubbieblue
Here is some info about the Crankcase Valve (CCV)
http://www.jeepforum.com/forum/f9/cc...mation-714560/
What does it matter if it is clean inside?
If you just replace the elbow will it stop the seepage?
post #7 of 8 Old 07-21-2010, 01:08 AM
wushaw
Rockin jeep
wushaw's Avatar
The rubber part in the valve cover gets hard over time and looses its ability to seal so it leaks. Yea if it's too bad then replace it.
wushaw is offline
post #8 of 8 Old 07-21-2010, 06:39 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Or just put an "O" ring under it. Did that 5 years ago and it hasn't leaked yet...
Knuckelhead is offline
ccv , crankcase , tj , wrangler , oil , leak
CCV - Crankcase Ventilation Valve Information Indiana TJ Wrangler Technical Forum 10 06-01-2015 08:04 PM
Crankcase Air Breather oil leak ideas funJ YJ Wrangler Technical Forum 0 05-18-2009 11:44 AM
Valve noise after replacing crankcase front seal Fernando YJ Wrangler Technical Forum 4 07-30-2008 11:43 AM
Oil Leak - new Valve Cover Force10 YJ Wrangler Technical Forum 12 11-16-2007 04:11 PM
Valve tap or exhaust leak? latham83 TJ Wrangler Technical Forum 7 01-23-2006 12:41 AM
