Crank position sensor test? - JeepForum.com
post #1 of 4 Old 06-20-2010, 08:41 PM Thread Starter
nvwoody
I have a 1998 Jeep Wrangler 2.5L. Manual Transmission and I am getting a P1391 code. I tested the cam position sensor and it tested ok. How do I test the crank position sensor?
nvwoody is offline
post #2 of 4 Old 06-20-2010, 08:54 PM
SoonerYJ
SoonerYJ's Avatar
2011 JK Wrangler
You might just remove it and clean it first, as the clutch wears the magnet will collect fragments and not read correctly, while its out inspect it for cracks.
___________
2011 Flame Red Rubicon (2-Door) with every option.
SoonerYJ is offline
post #3 of 4 Old 06-20-2010, 10:04 PM
Unbalanced
Any chance you've got access to a scope?
That's the only way I know of ~really~ testing one.
2003 TJ
2012 Overland
"Temporarily Detained" maybe, but ~never~ stuck...
Unbalanced is offline
post #4 of 4 Old 06-20-2010, 11:49 PM
JeepnBlake
A quick way to know is it will turn over, but it won't spark if it isn't working. The problem with that theory is however other things failing will do the same thing I.E. coil, cam sensor, and so on down the line.
I had a ZJ that those went bad every so often, we found out it was due to the valve cover gasket leaking, the oil would trickle down onto the CPS and cause it to fail.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
Crank Position Sensor 89/95 vintageagain68 YJ Wrangler Technical Forum 13 02-27-2015 02:11 PM
CPS (Crank Position Sensor) pwrbtr YJ Wrangler Technical Forum 1 08-23-2008 04:55 AM
crank position sensor mopl91 TJ Wrangler Technical Forum 2 11-17-2006 07:28 AM
Crank Position Sensor BLUE98TJ TJ Wrangler Technical Forum 8 04-18-2003 12:20 PM
Crank Position Sensor mattelderbaum TJ Wrangler Technical Forum 1 11-20-2002 02:56 PM
