crank position sensor - JeepForum.com
post #1 of 3 Old 11-17-2006, 04:44 AM Thread Starter
mopl91
Where exactly is the CPS located and how much of a pain is it to get out on a 97 Wrangler 4cyl?
mopl91 is offline
post #2 of 3 Old 11-17-2006, 07:10 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I've never looked on a 4 cylinder before, but I would guess its in the same spot that it is on all other Jeep models.
Look around the transmission bellhousing. Its usually on the driver side in about the 1-2 o'clock position.
Wheelin98TJ is offline
post #3 of 3 Old 11-17-2006, 07:28 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
had this in my gallery from a previous question...probably from the I6, but like the previous answer, your's ought to be in a similar position:
fairly easily reached laying under the driver's side behind the front wheel...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
Crank Position Sensor 89/95 vintageagain68 YJ Wrangler Technical Forum 13 02-27-2015 02:11 PM
CPS (Crank Position Sensor) pwrbtr YJ Wrangler Technical Forum 1 08-23-2008 04:55 AM
crank position sensor roadbosstx TJ Wrangler Technical Forum 3 06-24-2008 02:09 PM
Crank Position Sensor BLUE98TJ TJ Wrangler Technical Forum 8 04-18-2003 12:20 PM
Crank Position Sensor mattelderbaum TJ Wrangler Technical Forum 1 11-20-2002 02:56 PM
