crank with no start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > crank with no start
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 03-17-2012, 03:44 PM   #1
jeep4b4
crank with no start
I am having a bit of trouble with a friends jeep,it's a 2004 x.It cranks with no start,Gauges don't work,relays are good.Also when I turn the key 1 click 3 times i get no code,on mine it says done.I also can't hear the fuel pump kick on.I replaces the cam censer with no luck.I'm at a loss,can someone help?
Thanks
Dave
jeep4b4 is offline   Reply With Quote Quick reply to this message
Unread 03-17-2012, 04:30 PM   #2
Ross00TJ
Is the fuel pump working? How about the CKP (Crankshaft Position Sensor)?
Put a pressure gauge on the fuel rail and see if you are getting fuel when you crank, if not check your fuel pump with a multimeter to see if it is bad. Also check to see if you are getting spark when you crank. If not check your battery, alternator, and wiring.
Future Electrical and Computer Engineer - University of Colorado - Boulder | Bringing Logic to JeepForum since 2010!
"Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Ross00TJ is offline   Reply With Quote Quick reply to this message
Unread 03-17-2012, 05:10 PM   #3
jeep4b4
thanks
I'll check the CKP,the fuel pump doesn't come on when i turn the key,battery has a good charge in it.I'll also take a look at the rest of the things you talked about.
