CPS Sensor problem - JeepForum.com
post #1 of 3 Old 11-16-2010, 11:55 AM Thread Starter
dl425
CPS Sensor problem
So last weekend I go start up my jeep and it starts but then dies immediately, I restart it and manage to drive out of the driveway and it dies again. Did this a few more times. So I replace the CPS sensor and the problem goes away, starts running perfectly again.
Last night, about a week after replacing it, it does it again. So I know I have to replace the sensor again.
My question is what is causing the sensor to keep dying? and how do I fix it?
Thanks
2005 Wrangler 4.0L
2005 Red Rocky Mountain Edition
4.0 6 speed
Jeeperman Skidz-Body Armor front and rear bumpers
Rocky Mountain Edition Club Member #2
dl425 is offline
post #2 of 3 Old 11-16-2010, 12:05 PM
willydigger
Did you replace only the sensor or the whole drive assembly?
Have you seen this thread?
http://www.jeepforum.com/forum/f9/ch...d-read-963235/
willydigger is offline
post #3 of 3 Old 11-16-2010, 01:23 PM Thread Starter
dl425
Sorry I should clarify, by CPS I mean Crank Position Sensor, not Cam Position Sensor
4.0 6 speed
dl425 is offline
cps
TPS Sensor Problem Haleyrz TJ Wrangler Technical Forum 1 05-05-2009 01:33 PM
Could 02 sensor be the problem?? Jeep1067 TJ Wrangler Technical Forum 6 02-17-2009 06:58 PM
Sensor problem...i think GDM97TJ TJ Wrangler Technical Forum 22 09-01-2007 10:05 AM
Sensor problem - on my 4th O2 Sensor! sorny98se TJ Wrangler Technical Forum 9 11-22-2004 10:52 AM
sensor problem? razor TJ Wrangler Technical Forum 1 12-01-2002 07:28 PM
