Cowl Vent Door Flapping (Pic) - JeepForum.com
post #1 of 11 Old 06-27-2007, 08:47 AM Thread Starter
pendleton
I was working on my wiper motor the other day, and I had the cowl cover off. I noticed my HVAC vent door hanging freely down in it's enclosure. I have been having some vent problems for a while now, and while it is tolerable, it is not enjoyable. You can hear the darn thing flapping back and forth when driving over bumps and turning, (very annoying). I get water on the passenger floor board. Also, the A/C works great on coldest temperature setting, but if turned up warmer (still cold, but not coldest), the face vents blow cold while the floor vents slightly blow hot air (even when not on BI-Level). Is this door the culprit? What do I need to do to fix it?
pendleton is offline
post #2 of 11 Old 06-28-2007, 06:35 AM Thread Starter
pendleton
btt, I'm guessing this isn't a common problem. Also, as far as I can tell, my defrost vents are always blowing, even when system is turned off.
My Jeep:
post #3 of 11 Old 06-28-2007, 07:24 AM
frankiefire702
It apers according to my parts diagram you'll need to change out the whole upper housing to fix it. I'm sure it's not gonna be a small job.
06 tj locked on 36's.
frankiefire702 is offline
post #4 of 11 Old 06-28-2007, 07:44 AM
Rocky529
Rocky529's Avatar
While you may be able to replace just the door, it is more than likely you have to remove the entire evaporator case. It is not a small job, the dash has to be removed.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #5 of 11 Old 06-28-2007, 02:44 PM Thread Starter
pendleton
Frankiefire,
Do you have a part name identification chart that goes with your schematic diagram?
Take out the whole dash, huh guys?
My Jeep:
post #6 of 11 Old 06-29-2007, 06:39 AM
frankiefire702
1 HOUSING, Air Inlet
5073 172AA
2 HOUSING, A/C Upper
5073 175AA
3 HOUSING, A/C Lower
5073 176AA
4 MOTOR, Blower with Wheel
5066 553AA
5 RESISTOR, A/C Heater
5066 552AA
6 DOOR KIT, A/C And Heater
5073 184AA Includes Blend,Floor/Defrost,Panel Doors
7 ACTUATOR, Blend Door, Electric
5013 741AA
8 ACTUATOR, A/C and Heater, Panel Door
5073 181AA
9 ACTUATOR, A/C and Heater, Floor and Defrost
5066 518AA
10 VACUUM HARNESS, Heater and A/C
5073 182AA
11 HARNESS
5073 183AA
12 EVAPORATOR, Air Conditioning
5073 178AA
13 HEATER KIT, Heater Core Assembly
5073 180AA
14 SEAL KIT, A/C And Heater Unit
5073 174AA
15 55254848 WASHER, Sealing
16 ACTUATOR, A/C and Heater, Recirculating
5073 173AA
post #7 of 11 Old 06-29-2007, 07:03 AM
RockRunner85
Yep mine does this too. If I turn the a/c from the coldest it blows warm air on my feet.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #8 of 11 Old 06-29-2007, 08:16 AM
jzmtl
jzmtl's Avatar
So is that door suppose to be flip up and closed? Could be as simple as a spring clip fell out so it dosen't pop up anymore.
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it.
User CP > Options > Uncheck "Show Signatures"
jzmtl is offline
post #9 of 11 Old 06-29-2007, 08:34 AM Thread Starter
pendleton
I have no idea. I know that if you turn on the system, depending on which setting you select (Fresh, Recycle, etc.), the door does get sucked back up into position. Whenever you turn off the system, the pressure levels back out, and the door falls back open, and swings away.
My Jeep:
post #10 of 11 Old 06-29-2007, 08:38 AM
jzmtl
jzmtl's Avatar
Right, you have the luxury options knowns as A/C, so that's gona be more complicated.
jzmtl is offline
post #11 of 11 Old 08-24-2011, 06:31 PM Thread Starter
pendleton
Back from the archives. Four years later and I still haven't fixed this, but I would like to soon. Does anyone have any other ideas as to the problem, how to fix it, etc?
My Jeep:
cowl vent shaun72079 YJ Wrangler Technical Forum 7 10-01-2008 05:48 PM
cowl vent imjeepinVA TJ Wrangler Technical Forum 6 01-28-2008 09:37 PM
Snorkel into cowl vent? RODKNOCKER YJ Wrangler Technical Forum 4 02-27-2005 10:01 PM
Upper door flapping jeepin4me YJ Wrangler Technical Forum 18 01-28-2005 12:58 PM
YJ Door Uppers Flapping bcshepard YJ Wrangler Technical Forum 14 11-30-2004 06:02 AM
