cowl snorkel - JeepForum.com
post #1 of 3 Old 11-08-2003, 10:01 PM Thread Starter
Dome
cowl snorkel
Here's my stab at a snorkel. I've allways had my K&M filter inverted and hooked up to a cut off trottle body tube. It flows lots of air that way but the air is hot air. I cut the bottom of my air box off (bottom part of air box). I then put a new bottom on and cut a hole in the end of it. Now I'm able to run a striaght 2" pile throught the fire wall to pick up cool air. I think it will work very well. I was able to rid my self of one elbow. There is one elbow under the cowl pointing to the passager side. I don't have to take any thing apart to get to the filter. I can just unsnap it and pull the bottom(now the top) off and bam theres the filter.
Dome is offline
post #2 of 3 Old 11-08-2003, 10:09 PM
xyz123
Super Senior Member
interesting...how loud is noise inside the cab from the air flow?
xyz123 is offline
post #3 of 3 Old 11-08-2003, 10:21 PM Thread Starter
Dome
I haven't noticed any more noise at all. It doesn't flow as much air as before but what air is coming in the intake should be much cooler than before.
I should point out that I have a 1" body lift so there is a little more room than rigs without a BL.
Dome is offline
JK Custom Cowl Snorkel? warCryr JK Wrangler Technical Forum 111 11-07-2015 11:53 AM
ARB Safari Snorkel VS. Volant Snorkel pjleslie03 TJ Wrangler Technical Forum 42 07-16-2010 01:00 PM
question on cowl snorkel write up... majkowskid TJ Wrangler Technical Forum 11 07-23-2009 06:23 AM
Snorkel into cowl vent? RODKNOCKER YJ Wrangler Technical Forum 4 02-27-2005 10:01 PM
YJ cowl intake (snorkel). BamaJeeper YJ Wrangler Technical Forum 8 03-13-2003 12:46 AM
