Quantcast Cowl Induction - snorkle (WRITE UP) - Page 6 - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Cowl Induction - snorkle (WRITE UP)
Truck-Lite's New LED Headlamp SeriesTJ 5.25" Speaker Adapters - NalinMFGCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!
Old 08-21-2008, 03:29 PM   #76
jtice
Yes you have to take all those bolts out from around the filter canister to gain access to the filter.
I have not done this yet, I will give is a couple weeks then check it, see how it fairs.
~John
www.jtice.com
05 Jeep Rubicon
2.5" OME Lift, JKS BL/MML, JKS Trackbars, Rokmen TT Skid, Skid Row Engine Skid, ARB Bull Bumper, Warn M8000, Poison Spyder Rock Rails, Omix Front Diff Skid, Nth Degree Rear Diff Slider, Garvin Roof Rack, High Rock Rear Bumper
jtice is offline   Reply With Quote
Old 08-21-2008, 03:41 PM   #77
Hayseed
Hayseed's Avatar
Originally Posted by jtice View Post
I went with alittle different route, as I didnt want to have to get in the cowl to check/change the filter.
I used a K&N Apollo Intake kit.
~John
Me too but I didn't want the K&N so I used the stock airbox & filter.
Hayseed is offline   Reply With Quote
Old 08-21-2008, 04:24 PM   #78
provinT13
Wow so I don't think this will work with the yj, there is no gap like on the tj between the engine bay and the dash. I took my vent thing off the hood and what seemed to be the backside of my dash was in there.
2 Hands Working Do More Than 1000 Hands Praying
94 YJ Build
99 TJ Build
provinT13 is offline   Reply With Quote
Old 08-21-2008, 06:00 PM   #79
missionAvs
missionAvs's Avatar
All in all I am pleased, it went in pretty good, and JUST fit.
The stock tubing was cut to length, and attached to the Apollo housing using a rubber sleeve from Autozone.
Some electrical tape had to be wrapped around the stock tube and Apollo to get them to match up with the sleeve.
The sleeve was 3" and the tubes were about 2.75" OD.
The stock tube is a bit of a POS. Its quite sturdy, but thats cuz its THICK !!!
The ID is not very large at all, and not even round, this will get replaced with some nice metal tubing later on.
A 3.25" hole saw was used to put a hole in the firewall, there was barely room for it.
The hole was then lined with some rubber hose. Cut the rubber hose long ways, and slide it over the edge so there is no sharp edge.
Then the flexible end of the Apollo ran into the cowl, with the flared end on the end, like the end of a trumpet, inside the cowl.
Seat of the pants test drive around the block shows improvement
It sounds a bit better, after taking the carpet out, all I heard was fan noise, not it sounds like a motor again.
Not loud by any means, just a slight throaty sound.
It seems to have just a bit more pickup, or at least wakes up a bit earlier in the RPMs.
I will see how the gas millage goes though, and I am very interested to see how it does on hot days.
I was noticing a lack of performance on hot days.
~John
Set up looks good man! I was thinking about doing this mod with a KN Apollo filter as well. Do you have any pics from inside the cowl just to see how you placed the tubing in there.
Thanks
04 Willys Edition TJ Wrangler
missionAvs is offline   Reply With Quote
Old 08-21-2008, 07:28 PM   #80
jtice
Sorry, I forgot to take a pic under the cowl
There isnt much to that part though, that flexible tube that is supplied with the Apollo just runs into the cowl a couple inches,
and the supplied flared trumpet end is placed on the end of the tube.
~John
www.jtice.com
05 Jeep Rubicon
Old 08-21-2008, 07:29 PM   #81
Bigbob
Bigbob's Avatar
Originally Posted by jimaug87 View Post
Subscribed for later installation.
I have a 2005. Will i run into anything funky or will this write-up match my Jeep?
Great idea
Being he has the IAT in the tube he has a '05 or later.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 08-21-2008, 08:33 PM   #82
TJamz
TJamz's Avatar
Thanks
Where did you get that cover? How much if you don't mind me asking? Does a cone filter fit in there? I like that setup and am looking for different ideas on how to for the hummer intake located on the flange(?) above the hood.
I currently am running a k&n cold air intake package with the cone filter and want to modify that to run a cowl intake. I've seen a couple of writups on the idea but am looking for more info/ideas from the jeep gods before I get started.
TJamz is offline   Reply With Quote
Old 08-21-2008, 08:42 PM   #83
missionAvs
missionAvs's Avatar
Here's more info on it, http://www.knfilters.com/universal/apollo.htm . I have a buddy of mine that originally bought it from Advance Auto a little while ago but it didn't fit right with his set-up so he installed an ARB snorkel instead so he gave me the kit . I don't know how much it retails for but im sure a quick call to your nearest auto store would answer that question.
Old 08-21-2008, 08:45 PM   #84
missionAvs
missionAvs's Avatar
~John
Thats fine, just out of curiosity did you angle the Apollo tube towards the cowl vent or did you just stick it straight into the cowl?
Thanks for the help!
Old 08-21-2008, 09:36 PM   #85
jtice
you can find the Apollo UNIVERSAL kit for about $116 to $125 shipped.
I bent the tube over toward the vent a bit, and angled it down some.
That way if water were to pour in the vent, it would not just be pouring down the intake like a funnel.
~John
www.jtice.com
05 Jeep Rubicon
Old 08-21-2008, 09:40 PM   #86
PILL
You wont get better gas mileage with this. You may get better performance though.
This mod is great for getting your airbox up higher, and I really like it, but it will not improve your MPG's.
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline   Reply With Quote
Old 08-21-2008, 09:58 PM   #87
missionAvs
missionAvs's Avatar
~John
Cool thanks man.
Old 08-21-2008, 09:59 PM   #88
jtice
That all depends.
I personally know a couple ppl that have done similar setups and gained over 2 to 3 mpg.
For example, one guy had a REAL short tube, to a cone filter, but it sat right above the engine.
While that had very little resistance, it was pulling in Very hot air, thats probably the hottest area under the hood.
He extended the tubing, and places the cone filter in the cowl, and gained 3 mpg.
I have only been driving mine two days, but I can feel a slight difference.
Especially today, it was quite hot out, and my Jeep would noticably loose power on hot days.
But that wasnt the case today.
If you have a bit more power, you dont need to give it as much skinny pedal, and that should save gas.
I ordered a Scangauge II today, so I will also be doing some testing for intake air temps.
I will test a stock setup, and then mine, and see what difference in air temp there is.
~John
www.jtice.com
05 Jeep Rubicon
Old 08-21-2008, 10:33 PM   #89
bigchevyman24
Here's a couple pics with the 3.3L Buick airbox and with my pipe ran under the cowl for my hummer intake. And a link to my writeup for anyone interested:
http://www.jeepforum.com/forum/f9/tj-hummer-intake-write-up-buick-airbox-473981/
2000 WJ - I6, Auto, 2WD 2" BB, 18" JK wheels/32" tires, Converting to 4wd
---2WD TO 4WD CONVERSION---
97 TJ 4" lift, 35" boggers, lockright front D30, 9k winch - SOLD
95 XJ 33" TSL's, 2" BB, SEVERE trimming - SOLD
2003 WJ LIMITED PART OUT!!!!!!!!!
bigchevyman24 is offline   Reply With Quote
Old 08-21-2008, 10:34 PM   #90
PILL
That all depends.
~John
You get more power because your engine is getting more air and is able to burn more fuel. That decreases your mileage. At the RPM's you drive at to achieve the best mileage, the CAI has no effect.
Just ask these guys, they pretty much know most everything related to mileage with very few exceptions.
Glock Forum
