Quantcast Cowl Induction - snorkle (WRITE UP) - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Cowl Induction - snorkle (WRITE UP)
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 07-06-2008, 10:23 PM   #46
RLD831
Are the hard pipes with the built in elbow for the Civic Kits 2.5" OD pipe? That would be perfect.
Black 2001 Wrangler SE, stats in profile
RLD831 is offline   Reply With Quote
Old 07-18-2008, 12:18 PM   #47
Unscathed
Originally Posted by Roughneck View Post
I don't really care for the safari type exterior snorkles. I want a cowl snorkle setup but do you have to remove the cowl to change the air-filter?
Unscathed: what is that box thing under your hood? is that an air-filter box too?
1cleanTJ: could this what your talking about? 01-04 Honda Civic kit on ebay. The buy it now price was only $5.95. HOWEVER, the shipping was $27.
Well the black box thing is your wiper motor.. otherwise the box that is on passenger side is the Cabin Air dam that prevents water from getting in your cab.
Best Axles and service you will find. http://www.alljeep.com/oscommerce/index.php?cPath=32_617
The owner of Alljeep.com, Wayne Hartwig will work within your budget!!! He is very informative to anyone not knowing much about axle work and will meet or beat any competitor's advertised price on any specific product delivered to your door - even if he sells at cost!
Unscathed is offline   Reply With Quote
Old 07-22-2008, 09:53 PM   #48
NalinMFG
www.NalinMFG.com
NalinMFG's Avatar
i bought most of the parts to do this today. im going to skip the underhood airbox and pipe it straight from the TB. ill post up some pics as soon as i get around to doing it.
NalinMFG is offline   Reply With Quote
Old 07-22-2008, 11:03 PM   #49
BozoWise
If you have access to a welder most muffler shops will give you the scraps for free and you can save some $ I already had the plastic K&N tube off the throttle body but could have easily used muffler tube for the entire thing.
My 1 ton TJ build project "Evil Monkey": [url]http://www.jeepforum.com/forum/showthread.php?t=423989[/url]
BozoWise is offline   Reply With Quote
Old 07-22-2008, 11:17 PM   #50
cbowles
Has anybody done a smog/emissions test on this type of setup ... I live in CA, where god knows what would happen to me if I attempted this and tried to get a smog test... I'm not saying that it's not a bad idea, its actually quite awesome in fact, but smog might be a factor in making this for some people.
cbowles is offline   Reply With Quote
Old 07-23-2008, 09:13 AM   #51
Bigbob
Bigbob's Avatar
The answer is no.
It should pass the test just fine, but if it does not have the CARB seal of approval it won't meet the visual inspection. I am keeping all the stock stuff to put on for inspection purposes. I doubt it'll take 1/2 hour to go back like it was from the factory.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 07-23-2008, 09:51 AM   #52
ryanpurdy2004
so is there any serious co concerns about water getting Into this intake? I am going to do this mod but it seems like the air filter is quite vulnerable to water if it were to get under the cowl...
ryanpurdy2004 is offline   Reply With Quote
Old 07-23-2008, 10:22 AM   #53
RON310
why not just run a pipe to the cowl, but leave the filter under the hood?
This way you don't have to remove the cowl when you want to check or change the filter...
RON310 is offline   Reply With Quote
Old 07-23-2008, 10:44 AM   #54
Giviner
That is what a lot of people do. You can get an airbox from an early 90's buick with the 3300 V6 and it works quite well from what I've seen.
Here's a link from bigchevyman24's writeup........there are a few more linked in this thread.
http://www.jeepforum.com/forum/f9/tj-hummer-intake-write-up-buick-airbox-473981/
I will be doing this myself soon, just picked up the airbox last week so now I just need to hit up the hardware/auto parts stores for the rest of the pieces.
2003 TJ Sahara
1988 XJ
www.jeepsofmcmurray.ca
Giviner is offline   Reply With Quote
Old 07-23-2008, 10:58 AM   #55
Bigbob
Bigbob's Avatar
The cowl has a drain. If the drain is plugged you have troubles regardless if you have a filter in there or not. If you put a scoop on the cowl intake grill aimed back the odds of getting any large amount of rain water in there is pretty slim. If you are talking about fording a river and submerge the Jeep in water that high you are screwed in many ways other than just getting water in the intake.
That would be better than the stock set-up probably, but remember, the air box is an oven mounted under the hood. If there is some way you can insulate it then that would make things better. Actual cold air needs to be inducted into the engine. As close to outside ambient air temp as possible is what is needed. And even if you just keep the stock set-up move the IAT sensor out of the manifold and into the air tube. The '05 and '06 models have it in the air tube. The manifold is a heat sink and causes false readings to the sensor. Very important mod that does a lot of good.
6 Speed, Hardtop
Old 07-23-2008, 12:01 PM   #56
Unscathed
I kinda would rather use PLASTIC over steel and what not as far as condensation and rust is concerned. Yea you can paint it, but the pain is going to chip eventually and shoot down into your intake.. Just my 2 cents.
The only reason I have that airbox popping off of the intake is simply because I was working on another project trying to make my own using different parts from junkyards, but I realized that all I did was waste time and money in "Trial and Error"
I wrote the write-up for anyone that wanted a one stop shop solution.
I created the intake for
1- Clean cooler Air
2- Better Airflow
3- Kinda for deeper water driving, not that I do much of it, but I would rather know when my intake is sucking in water rather then hoping it isn't fording through water.
Old 07-24-2008, 12:48 PM   #57
Luck881
I'd like to see pics if anyone tried this with a 2.4L. It seems alot more crowded up around the fire wall...
Anyone think it would work here?
Ian
'05 TJ SE, 2.4L, 6 Spd, 2" Procomp Lift, 31" M/T MTZ's
'09 Ram QC SLT,2.5 levelling kit to come
Luck881 is offline   Reply With Quote
Old 07-24-2008, 02:05 PM   #58
Bigbob
Bigbob's Avatar
Sure would. All those wires just can be laid over the top of the tube. Same firewall as a 4.0
6 Speed, Hardtop
Old 07-24-2008, 02:10 PM   #59
Luck881
Could the angle or closeness cause any problems? It looks really tight.
Ian
Old 07-24-2008, 02:35 PM   #60
Bigbob
Bigbob's Avatar
Nope. A quick 90 and right into the cowl.
6 Speed, Hardtop
Glock Forum
