Cowl Induction - snorkle (WRITE UP)
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#16 | ||
the honda intake tube is angled on the end you put in the cowl already and you just buy a hole saw that match's the tube diameter and toss a little silicone around the edge where it meets the firewall
Click here --> - Buy popular magazines at discounted price, help my daughter for school DIY jeep highline guide -> click here DIY highline guide Save up to 40% off at advance auto parts by buying online, pick up at store free! |
#17 |
Any noticeable difference in power due to drawing in colder air?
#18 |
Wahoowa
That's real cool. That set up looks like it will also help keep you from hydrolocking the engine.
White 01 TJ Sport 4.0 NV3550 |
#19 |
I turned the filter with a 90 degree elbow because I didn't want it over exposed to the vent... Ie, WATER intake..
Actually yes, I noticed a power difference... my throttle response was a lot better and my gas mileage seems better, but I will know more after I run this full tank of gas out. Without the radio on, It makes a cool sound when you step on it... like a Woooosh sound.. Definitely make you aware that you are stepping on it... lol
Best Axles and service you will find. http://www.alljeep.com/oscommerce/index.php?cPath=32_617 The owner of Alljeep.com, Wayne Hartwig will work within your budget!!! He is very informative to anyone not knowing much about axle work and will meet or beat any competitor's advertised price on any specific product delivered to your door - even if he sells at cost! |
#20 |
My snorkel is almost done. Same idea.
http://www.jeepforum.com/forum/f9/up-down-splash-water-crossing-precautions-524994/index2.html
Just do it |
#21 |
This looks pretty easy might just do this tomorrow for my Jeep. Thanks for the step by step
#22 |
Some Call me RockDog
I like it. I may do it this summer. I have a K&N cone already and plan on reusing that. I would probably add a paper filter on the engine when I do it.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#23 |
Keyser Soze
im doing this
#24 |
Awesome write-up, Unscathed.
#25 |
Hehe.. thanks
#26 |
hey, do you think the filter will see much water wher it is mounted or would you have to place a splash shild over the top of it becasue we see alot of hard rains here in fl.
#27 |
Just make sure your drain is clean under that cowl- you get that clogged and you might as well put your intake in a bucket of water
Dave 04 Wrangler Sport 4.0 1990 VW Corrado Turbo 1998 VW Jetta TDI 1999 VW Jetta TDI 4 SALE!! |
#28 |
drilling thru the fire wall did you just get a very large hole saw? and the box over your intake is that the old style tj box could you just run the hose to the tb on a newer tj
#29 |
hole saw.. yes.. Although if you are using my method with the two ducts, go as big as the duct diameter itself that way the hole is not to big and the pipe fitting will fit through it almost snug.
and you can run the hose to your current Intake piping just fine, just cut the pipe. The box you see in my photo's was from another airbox project since my old intake pipe shat the bed and I just kept using it since it had the return air line petcock for the engine gases. And onlyn8v is right.. make sure that drain is clean.. or you can either have an intake full of water, or a passenger side cab full of water driving down the road.. lol. Remember, in my setup, I took out that AC air dam and pounded down some of the metal as I was working with another setup before this hit me. I am thinking of putting it back in with some minor fabrication or even putting a small dam of sorts to keep water out off the floor of the jeep in a down pour. Normal rain isn't a big thing, but a torrential downpour might result in wet floors ![]()
#30 |
if you put something like this on you could possibly get a ram air effect as well as help keep water out.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
