couple questions about a rubicon - Page 3 - JeepForum.com
post #31 of 35 Old 07-04-2010, 07:50 PM Thread Starter
APEDZ04LJ
well iwent to look at the pics of this rubi and lucky me its sold
APEDZ04LJ is offline
post #32 of 35 Old 07-04-2010, 08:11 PM
remery829
Originally Posted by RubiconRazorbac View Post
Even though it's a fixed yoke, it doesn't have a double-cardan (cv) driveshaft. So you're still susceptible to adverse driveline angles when you lift the Jeep.
To get rid of the t-case drop you'd still need a driveshaft & some upper adjustable control arms to adjust the pinion.
The fixed flange DOES make this much easier since you don't have to modify the t-case. The driveshaft upgrade just bolts right up.
i have a dc rear drive shaft in my rubi....
Ryan
vvvthis is what they don't tell you about LCGvvv
...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...
SUPPORT OUR TROOPS
remery829 is offline
post #33 of 35 Old 07-04-2010, 09:53 PM
RubiconRazorbac
RubiconRazorbac's Avatar
So do I, but it didn't come from the factory that way...
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #34 of 35 Old 07-04-2010, 10:06 PM
kuruma
I will eventually. Gotta have a garage sale.
kuruma is offline
post #35 of 35 Old 07-05-2010, 08:12 AM
jknutter
jknutter's Avatar
Another Rubi option that was not mentioned here is the Rubi also has 4 wheel disc brakes. Small but significant...
2005 TJ Rubicon & 2014 WK2 Overland
jknutter is offline
rubicon , tj , wrangler , lj , trade , selling , tire , size
New Rubicon Owner.... Couple ?'s TB2211 JK Wrangler Technical Forum 15 06-16-2010 04:41 PM
Rubicon Stuck in deep mud. Couple of questions alexr40 TJ Wrangler Technical Forum 14 04-06-2009 05:58 PM
Couple questions about the JK AvyZJDriver JK Wrangler Technical Forum 9 02-20-2009 11:07 PM
Hello! New Member, building a 06 Rubicon & I've got a couple questions... SeanO TJ Wrangler Technical Forum 5 09-23-2008 05:43 AM
Couple Rubicon Q's mmhsval TJ Wrangler Technical Forum 8 01-27-2004 02:49 PM
