couple questions about a rubicon - Page 2 - JeepForum.com
post #16 of 35 Old 07-03-2010, 11:22 PM
NoVaHunter
Originally Posted by Jay12 View Post
that's the D30's stats
Yeah I just went and did some reading, I now know that
Originally Posted by KHoff90 View Post
Has anyone really been far even as decided to use even go want to do look more like?
NoVaHunter is offline
post #17 of 35 Old 07-03-2010, 11:32 PM
kuruma
NoVaHunter: Rubicon has a fixed yoke already??? Didn't know that. Why would someone put a transfercase drop kit when installing a cheapo lift if it already had a fixed yoke? Would you just need longer drive shafts to eliminate the transfercase drop?
GreenJeeper92: Sorry about the threadjack, Brother. Some info came to light on here to me that might save me some cash. For what it's worth, I'd say get the Rubi. I have a Rubicon Unlimited and it's very nice. I'm learning how it works more evrytime I take it out and am very impressed with its capabilities. Now if I can get rid of that transfercase drop I'd be a happy camper.
kuruma is offline
post #18 of 35 Old 07-03-2010, 11:40 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Even though it's a fixed yoke, it doesn't have a double-cardan (cv) driveshaft. So you're still susceptible to adverse driveline angles when you lift the Jeep.
To get rid of the t-case drop you'd still need a driveshaft & some upper adjustable control arms to adjust the pinion.
The fixed flange DOES make this much easier since you don't have to modify the t-case. The driveshaft upgrade just bolts right up.
Your shaft isn't long enough to handle that kind of droop...
My build thread:
RubiconRazorbac is offline
post #19 of 35 Old 07-03-2010, 11:41 PM
NoVaHunter
Yeah it has a fixed yoke. Despite that, the driveline can still be uneven, therefore the tcase drop comes into play. I have one and its horrible
post #20 of 35 Old 07-03-2010, 11:48 PM
kuruma
Thank you Gents,
You may have saved me some cash there, but made me look like a fool. LOL I already sent some inquiries to Tom Wood, as far as drive shafts go, and referencing a slip yoke eliminator. Oh well, this is one of the reasons I signed up here, to gain knowledge. So a longer driveshaft and look into Adjustable Upper Arms. Gottcha!
GreenJeeper92: On second thought, maybe you shouldn't get the Rubi. It seems to come with an advanced case of "I want more stuff to make my jeep invincible" itis. LOL
kuruma is offline
post #21 of 35 Old 07-04-2010, 02:40 AM
BlueFlame
BlueFlame's Avatar
Well see, that's the thing.
If you'll be staying stock or only be mildly building it (say for 33s or less and average trail riding) then the Rubi can be a great choice, might actually save you money.
But if you're going to build for 35s and do some serious wheeling, the only thing the Rubi gives you that's any good is the Tcase. The axles are not stronger, 4.10s are not enough, and the lockers are weak and will need to be upgraded eventually.
(and that factory 'armor' is joke...)
BlueFlame is offline
post #22 of 35 Old 07-04-2010, 06:38 AM
RubiconRazorbac
That happens with ALL Jeeps!
You'll be fine on 35s. Of course shafts need to be upgraded if you're doing "serious wheeling." 4.10s suck on the road, but are just fine on the trail. I wouldn't buy the lockers if they didn't come with the axles, but they're strong enough for what a huge majority of folks do on 35s. If mine go, I'll replace them with ARBs.
I still haven't found a good use for the "factory armor" sitting in my garage
My build thread:
post #23 of 35 Old 07-04-2010, 07:03 AM
robncar
robncar's Avatar
The 241 transfer case would be nice with its 4:1 reduction compared to the 231 with its 2:71 reduction. It would also be nice to have that front D44 as it has the capability to gear to 5.13. There is a savings in not needing an SYE and only having to buy a CV style drive shaft. Its the rear locker on the Rubi's that have issues because they double as a limited slip. Some folks have installed a front Rubi locker (non-LSD) in the rear axle and been good to go. Starting with a Rubi base would have saved me money and I'd have a better rig now.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #24 of 35 Old 07-04-2010, 07:26 AM Thread Starter
APEDZ04LJ
thanks for all the info guys, im gonna call up the dealer and maybe in a couple weeks go down and check it out, if it s already geard to 35,s and has the cv and what not who knows what ill do
APEDZ04LJ is offline
post #25 of 35 Old 07-04-2010, 09:39 AM
solarpower
I did it right the first time and got the Rubicon...
but what you don't see is the extra stuff..armor, bumpers, rockers, chromo shafts etc. etc. that you may very well want to have before you go blazing trails on bigger tires.
there is quite an added expense in using those lockers often..you may want to shop around for a less expensive Rubicon with a few more miles and nothing done to it. I have seen them for less than 15k...
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #26 of 35 Old 07-04-2010, 10:03 AM
briguy3030
GreenJeeper, I absolutely love my Rubi, but you could very well find yourself missing the extra space of the LJ as much as you like the prepackaged Rubi setup.
After, skimming across the previous posts, I believe it's been said that your LJ does indeed already have the typical D44 rear, D30 front LJ setup. That said, a Rubicon does have a true D44 rear. The front, however, is where it gets hybrid-like w D44 pumpkin & gears, while the shafts, knuckles & the like are D30 parts.
Disclaimer . . . I'm pretty confident this is the correct info but, if not I apologize. I by no means am a guru but I attempt to provide a clarification when I feel able.
That being said, the money taken out on a loan to gain the air lockers, gearing, & NP241--while losing the valuable storage space & more desirable wheel base of the hard to find LJ--could be spent on your LJ to accomplish the same. I would recommend get some ARB's, regear (to an even better 4.56 or 4.88 for 35's), & possibly go Atlas II if you so felt the need.
Nonetheless, you'll be happy whatever direction you decide to take!
RUBICON
"You miss 100 percent of the shots you never take."
-Wayne Gretzky
briguy3030 is offline
post #27 of 35 Old 07-04-2010, 10:42 AM Thread Starter
APEDZ04LJ
Well my situation is i hate auto with a passion , its no fun to drive, what i was planning to was keep my front warn bumper winch my audio setup and seat covers and put the stock parts on and sell the lj, but id but t rubi if its regeared already and so on because i dont want to put 4000 grand in the lj to do 33's, then sell it at 150,000 miles, where i could get the rubi ready to go on 35s hopefully and just throw my stock flares on and some armor and buy some new tube steps, idk what im gonna do, i love the color of my lj but im 18 and dont need a rear seat in it so i can throw some stuff in the back
post #28 of 35 Old 07-04-2010, 11:07 AM
briguy3030
Yeah, in the 2 years I've had my TJ I've only had back seat occupants once or twice; male friends prefer just not to cram in there--I guess its the 'Zoolander effect.' And being 29, I've found the Jeep no longer has the same effect on chicks as say girls of your demographic.
Therefore, I keep the rear seat in my garage & use the back tub for hauling my tools (Union Ironworker) & camping trips. Nonetheless, I still find I rely on my Yakima Sports Cage rack in the summers for camping as my two coolers take up the entirety of the TJ tub for camping.
It sounds like you've got your 'ducks in a row' so to speak & will love the Rubi's capability . . . I sure do. I think the only other way I would trade my TJ Rubi would be for an LJ Rubi. Best of both worlds IMO.
RUBICON
-Wayne Gretzky
post #29 of 35 Old 07-04-2010, 11:20 AM Thread Starter
APEDZ04LJ
Now thats the ultimate setup an lj rubi!
post #30 of 35 Old 07-04-2010, 07:55 PM
kuruma
Yes....yes it is.
kuruma is offline
rubicon , tj , wrangler , lj , trade , selling , tire , size
New Rubicon Owner.... Couple ?'s TB2211 JK Wrangler Technical Forum 15 06-16-2010 05:41 PM
Rubicon Stuck in deep mud. Couple of questions alexr40 TJ Wrangler Technical Forum 14 04-06-2009 06:58 PM
Couple questions about the JK AvyZJDriver JK Wrangler Technical Forum 9 02-21-2009 12:07 AM
Hello! New Member, building a 06 Rubicon & I've got a couple questions... SeanO TJ Wrangler Technical Forum 5 09-23-2008 06:43 AM
Couple Rubicon Q's mmhsval TJ Wrangler Technical Forum 8 01-27-2004 03:49 PM
