Cost to replace clutch? - JeepForum.com
post #1 of 8 Old 03-12-2012, 09:59 PM Thread Starter
bgoman
Could someone give me a rough estimate on replacing a clutch on a 2002 TJ if taken to a shop? Just blew it out tonight. Feel like an idiot cause I felt it slipping but it just didn't register. I'm a Triple AAA member and they have an auto center nearby so I'm hoping I might get some kind of discount. But, would it be hard to do myself? I did one in auto class a few years ago and my friends are very knowledgeable. Only problem is that I'm on a college campus so it'd have to be done in the parking lot without air tools. Thanks.
bgoman is offline
post #2 of 8 Old 03-12-2012, 10:10 PM
LiveAndLearn
its really easy on a jeep. dont really need air tools at all.
LiveAndLearn is offline
post #3 of 8 Old 03-13-2012, 02:09 AM
TheBoogieman
Dead Jeepers Club
TheBoogieman's Avatar
Not too hard if you have a tranny jack and a friend.My buddy paid $650 to have his clutch replaced(clutch kit with new fork,master and slave cylinders too).
p.s. If you DIY,don't overtorque the pressure plates bolts or you'll be very sorry when you go to drive it.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #4 of 8 Old 03-13-2012, 05:22 AM
taztj
I was qouted at $625 once. I ended up doing it myself. Do replace all the components the kit comes with since you are at it (throwup bearing, plate, fork and what not). Do rent a tranny jack and NOT a jack adaptor. I had the transmission slip twice with the adaptor and almost lost my arm. Biggest PITA was removing the torx screws on the top of the bellhouse and realingninig the dam transmission. Good luck
taztj is offline
post #5 of 8 Old 03-13-2012, 05:26 AM
Muddeprived
Muddeprived's Avatar
Is there a write-up on the web somewhere for this fix? I'd like to bookmark it for future references. I just got a 99 with 81k miles so I'm assuming I'll need to do some work on the clutch in the next few years depending on how nice I am to it.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #6 of 8 Old 03-13-2012, 05:32 AM
NotURMailman
NotURMailman's Avatar
It is not that hard to do, even without a tranny jack.
If you don't have a tranny jack, buy enough fluid to change the tranny and t-case oil.
Drain the t-case and remove it fro the tranny.
Drain the tranny.
With the tranny drained you can lay on your back and lift up on the tranny while you slide it back off of the engine, assuming you are of reasonable strength.
It's not the idea method, but I did quite a few clutches like that in my younger days.
Just be careful, and only attempt this if you feel comfortable lifting the tranny!!!!
Don't try to be a tough guy and lift a trany that is too heavy for you!!!
I do not know you and do not know if you are capable of this or not!!!
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #7 of 8 Old 03-13-2012, 08:57 AM
Muddeprived
Drain the tranny.
That's pretty much what we did when we swapped in a used 3 speed auto in my old 2000 TJ. It was pretty heavy BUT not heavy enough to crush me. Is the 3 speed auto heavier than the 5 speed manual?
post #8 of 8 Old 03-13-2012, 11:18 AM
happymudder10
Here you go:
http://4x4xplor.com/clutch.html
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
How much should a new clutch cost to replace? Dfrugia YJ Wrangler Technical Forum 3 12-04-2011 07:09 AM
Cost to replace ring and pinion Porchdog JK Wrangler Technical Forum 21 04-05-2011 03:36 PM
Average cost to replace a clutch tj7695 YJ Wrangler Technical Forum 26 03-03-2011 05:26 PM
Cost to replace exhaust manifold? shaggy105 TJ Wrangler Technical Forum 3 04-03-2009 02:17 PM
Average cost to replace clutch in 94 4.0? Tony1 YJ Wrangler Technical Forum 4 12-10-2003 11:11 AM
