Corner Guards - JeepForum.com
post #1 of 31 Old 04-17-2006, 02:12 PM Thread Starter
stathunter
Corner Guards
Hey I never thought that I would like corner guards but I just looked at a buddys jeep unlimited and he had the mopar corner guards with the small rock rail on them-----it looked very good and they were pretty solid. I have always been afraid of the mosture thing getting behind them---his has a rubber gasket on them that might help this but certainly will not prevent it.
Does any one have a set they recommend? Anyone have the rail thing on theirs?
Is there any manufacturer that is thicker than others? Anyone have experience with these? Thanks
stathunter is offline
post #2 of 31 Old 04-17-2006, 03:09 PM
JJs99TJ
i dont know about the Mopar ones, but im sure theyre pretty $$$$
a lot of people run PSCs Trail and/or Crusher Corners
the trail ones run ~ $140 cover the corner
the crushers run ~ $280 cover from the corner to the door
check out: http://www.spydercustoms.com/index2.php
JJs99TJ is offline
post #3 of 31 Old 04-17-2006, 03:22 PM
erickpl
erickpl's Avatar
Only ones I know of that have bars on them are the Toys by Troy ones. You can see them on Stu's site.
http://www.stu-offroad.com/guards/tbtside/ss-1.htm
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #4 of 31 Old 04-17-2006, 03:30 PM Thread Starter
stathunter
Thanks ----The one on stu's site are HUGE! Wow---Stu if you are there does Troy have any new products with something a little smaller?
Does anyone have the mopar ones?
http://www.jeepworld.com/accessories...rnerguards.htm
post #5 of 31 Old 04-17-2006, 04:57 PM
bryans98tj
I have PSC trail corners and love them. Pretty easy to install if you aren't shy about putting holes in your Jeep. As far as a moisture guard goes you can run a bead of clear silicone and/or paint the corners with a bed liner. I haven't done either yet but I will come this spring when the weather gets a little more dependable.
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #6 of 31 Old 04-17-2006, 05:25 PM
stogie25
stogie25's Avatar
I siliconed the top and sides, and left the bottoms open. I have Poison Spyder trail corners. They are pretty sturdy.
The powder coating likes to bubble, so I take them off every year to repaint them. There is no rust at all underneath.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #7 of 31 Old 04-17-2006, 06:04 PM
bryans98tj
I hear you there stogie. A couple of corners on my corners were missing powder coat. I emailed PSC just to let them know of the problem. Not looking for any replacemnt as to me finsh isn't why I got them. I agree with taking them off to paint and clean underneath-especially if you live in a salt area.
كافر - Infidel
post #8 of 31 Old 04-17-2006, 06:55 PM
JeepCreepn01
JeepCreepn01's Avatar
i run PSC now but my YJ had these on them, very sweet and IMO better then PSC especially with the powder coating
http://www.offyourrockers.com/
JeepCreepn01 is offline
post #9 of 31 Old 05-07-2006, 02:38 PM
bondo303
bondo303's Avatar
Originally Posted by stathunter
I have the Mopar corner guards. They are pretty heavy and also cost a good penny. I had credit from the Jeep Dealership so they only ended up costing me about $50. I got the smooth steel, not the diamond plate. Also, I wanted to get the guards with the rail but they were only for the Unlimited and cost $100 more.
02 X Amber Fire
48 CJ2A
bondo303 is offline
post #10 of 31 Old 05-07-2006, 04:57 PM
RedefinedTJ
I am planning on getting some crushers.... look pritty nice
RedefinedTJ is offline
post #11 of 31 Old 05-07-2006, 10:33 PM
Wooders
1975 CJ6
I have the TBT side sliders & corners - they aren't small - but they are very solid and offer great protection.
My poser pic...
Cheers
Wooders is offline
post #12 of 31 Old 05-07-2006, 10:53 PM
06WranglerX
Not to but in on the conversation at hand but i am installing a set of conner guards on my jeep sometime this week and would like to know if running a bead of silicon around the top is nesscary. I am trying not to have moisture build up under them. Or is that something i should not even worry about with them as it should dry before harm is done? Please advise if you could.
06WranglerX is offline
post #13 of 31 Old 05-08-2006, 07:45 AM Thread Starter
stathunter
I am thinking that silicone on the top is good but I am guessing that leaving the bottom open so any moisture will drain out is probably best.
Scott
2004 Black X w/ RE LA 37" SSR's, etc etc
In Michigan? Call Jim from
"Do or do not, there is no try" Yoda
post #14 of 31 Old 05-08-2006, 10:52 AM
JeepCreepn01
yep, that works best
post #15 of 31 Old 05-08-2006, 12:03 PM
RUB1CON
RUB1CON's Avatar
I have the PSC corners sitting in my garage I bent up some 1" solid stock and welded it on the corners looks pretty good now all I have to do is paint them and install them
'03 Rubicon
RUB1CON is offline
TJ Corner Guards The Rat YJ Wrangler Technical Forum 3 08-29-2008 09:16 AM
corner guards!? 03_X TJ Wrangler Technical Forum 15 04-16-2008 07:03 PM
Corner Guards... Wheels4186 TJ Wrangler Technical Forum 11 10-07-2006 09:18 AM
Corner Guards AZSahara TJ Wrangler Technical Forum 15 01-23-2006 10:30 AM
OYR corner guards white TJ TJ Wrangler Technical Forum 8 07-28-2002 09:50 AM
