corner guards - JeepForum.com
post #1 of 9 Old 04-18-2005, 04:01 PM Thread Starter
TJxcore
corner guards
looking into getting come corner guards. just wondering who else makes them besides poison spyder? thanks
TJxcore is offline
post #2 of 9 Old 04-18-2005, 04:06 PM
tem_jr
Toys by Troy also has some.
'04 SILVER X
Teraflex 3T/Teraflex Shocks/Teraflex Modular LCA's/33" MTR/15x8 MT Classic II/Quick Discos/True Flow Air Filter
tem_jr is offline
post #3 of 9 Old 04-18-2005, 09:21 PM
dakuda
Admin
dakuda's Avatar
ORO makes them as well, I think they do the diamond plate variety.
As far as TBT, I hope their powdercoating has improved. The powdercoating on mine is coming off after less then a year. The worst part is that I ordered them bare steel, but I took what I got. I have heard they had some problems with that though, and that they have fixed whatever it was.
Oh yeah, and the bushwacker ones are plastic. Just so you kow beforehand.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #4 of 9 Old 04-18-2005, 09:41 PM
kidw/yj
warrior at quadratec
like $105 or sompthin
_______________________
being rebuilt
summer 06 beast will be unleashed
kidw/yj is offline
post #5 of 9 Old 04-18-2005, 09:51 PM
03jeeper78
03jeeper78's Avatar
There are some in the Mopar accessories catalog. Diamond plated ones, and also some with a rail on the side. They're fairly expensive, of course.
03jeeper78 is offline
post #6 of 9 Old 04-19-2005, 10:04 AM
erickpl
erickpl's Avatar
Stu Olson showed some pics from his site that integrates the rear corners with additional protection and rails from the corner, over the rear flares up to the door edge.
TbT Side Sliders / Rear protection
I would assume these pieces would work with PSC corners too, but I'd probably go TbT all the way around to make sure the fit was good.
Stu, ya out there?
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #7 of 9 Old 04-19-2005, 03:51 PM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
I got a set from a guy called "grimjeeper" on e-bay. black powder coated and shipped to my door for 90$. Fit was good and they've done their job on more than one occasion.
lj
ಠ_ಠ
LoneJeeper is offline
post #8 of 9 Old 04-19-2005, 05:51 PM
chris06
chris06's Avatar
i have the Toys By Troy corners. i like them a lot and they fit good. it just might take TBT forever to get them to your door.
2000 Black Sahara
Toys X Troy Croners
LED's
chris06 is offline
post #9 of 9 Old 04-19-2005, 06:29 PM
Stu Olson
Stu Olson's Avatar
Stu, ya out there?
Yes, I am, but I wouldn't recommend fitting them to an other brand of rocker guard and corner guard unless one doesn't mind the possibility of doing some fitting. Troy made some slight changes to his corner guards since I first got mine....this resulted in my having to trim to get things to fit. I knew that going into it and it didn't bother me....but others may not wish to go that route.
Mixing and matching guards in this fashion would be along the same lines getting the windows from one soft top maker and believing they would zip right into another manufacturers top. Maybe they will fit....maybe they won't.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
TJ Corner Guards The Rat YJ Wrangler Technical Forum 3 08-29-2008 09:16 AM
corner guards!? 03_X TJ Wrangler Technical Forum 15 04-16-2008 07:03 PM
Corner Guards... Wheels4186 TJ Wrangler Technical Forum 11 10-07-2006 09:18 AM
Corner Guards AZSahara TJ Wrangler Technical Forum 15 01-23-2006 10:30 AM
OYR corner guards white TJ TJ Wrangler Technical Forum 8 07-28-2002 09:50 AM
