Corbeau Baja XRS seats - JeepForum.com
post #1 of 9 Old 11-19-2013, 11:17 PM Thread Starter
sduncan
sduncan's Avatar
Just installed the new seats.. I decided on the Corbeau Baja XRS along with their direct fit brackets. The install was bolt in easy.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #2 of 9 Old 11-19-2013, 11:27 PM
chmo
Nice ... I know they are reclining ... but do they tumble forward for rear access as well with this bracketry?
Suspension seats are on my wishlist ... but not sure yet about brand (PRP? MC? Corbeau?), model (reclining? bucket? memory foam?) and options (OEM tumble forwad, adjustable lumbar support)
The cost factor (including shipping) is another constraint as well as quality concerns (MC AND Corbeau both meanwhile have low budget entry level import models ... are they up to quality expectations or just slightly overpriced noname junk?)
"The more I know, the more I realize how much I don't know"
chmo is offline
post #3 of 9 Old 11-19-2013, 11:33 PM Thread Starter
sduncan
sduncan's Avatar
With their brackets the tumble part is gone. If you use the adapters you keep the tumble but gain about 1-1.5 in in height. I didn't want that and no one but the small grandkids rife in the back every once in a while..I really won't miss the tumble function of the OEM seats. They seem to slide forward about as much as the factory seats.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #4 of 9 Old 11-20-2013, 12:03 AM
willis36
willis36's Avatar
Is there any rubbing on the center console or on the rollbar with the seat slid all the way back? Could you post some pics of the clearance?
willis36 is offline
post #5 of 9 Old 11-20-2013, 06:54 AM
Teeka
2011 JK Wrangler
That seat mount is different then the one I got.
Driver side wouldn't go in because the bolt was hitting centre council.
If they would of sent me that mount I'd be wheeling this weekend instead of being winch b@$&
Teeka is offline
post #6 of 9 Old 11-20-2013, 09:24 AM
Skold
Those look REAL nice! Thanks for posting. It looks like you have room for some amps under there too if you wanted! Did you have to drill new holes, or did they use factory mount holes?
Skold is offline
post #7 of 9 Old 11-20-2013, 04:17 PM Thread Starter
sduncan
sduncan's Avatar
Teeka,
What year is your TJ? These mounts are for 97-02 models.
Skold,
They bolt to the factory holes with factory hardware. Remove the old seats, swap the seat belt latch to the new ones ( a place is provided) mount the Corbeau brackets to the new seats using their hardware, and reinstall using the 3 hex head and one Torx as original.
I'll add a few more pics to show how they fit in the jeep with the factory center console....stand by.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #8 of 9 Old 11-20-2013, 06:13 PM
Teeka
2011 JK Wrangler
2003. I sent back the clip harness for a bolt harness. Hopefully that will fit better.
Teeka is offline
post #9 of 9 Old 11-21-2013, 05:36 AM
s62e39
Those look great! This might be my next mod after seeing how good yours look
s62e39 is offline
