coolent leak??? - JeepForum.com
post #1 of 8 Old 05-17-2010, 07:13 PM Thread Starter
bobadeep
coolent leak???
I keep replacing coolent in my radiator but can not find a leak. Put dye in the water but nothing. Any ideas?
bobadeep is offline
post #2 of 8 Old 05-17-2010, 07:18 PM
KillaBeave
Burning? Getting into combustion chamber through blown head gasket? Do you have any white smoke?
Another Jeep Noob ...
KillaBeave is offline
post #3 of 8 Old 05-17-2010, 07:21 PM Thread Starter
bobadeep
No smoke and runs about 195 to 200 degrees
bobadeep is offline
post #4 of 8 Old 05-18-2010, 11:16 AM
Pig_Pen
The plastic topped radiators are well known for leaking. Check inside the shroud and see if it is running down the passenger side of radiator, how does the underside of the water pump look? Check for whitish streaks there and on thermostat housing, most coolant leaks leave a snail trail of white streaks if they are temperamental leaks. If all is good there pop the oil cap and check for signs of water/oil mix.
Pig_Pen is offline
post #5 of 8 Old 05-18-2010, 11:51 AM
TheBeast
Mine did exactly that. The plastic crimped seal on top was slowly leaking and dripping down slowly enough not to leak on the ground. I can smell the coolant while driving and while in the garage. The pic below shows the left side leaking.
TheBeast is offline
post #6 of 8 Old 05-18-2010, 02:12 PM
JeepGuy365
Thanks for the picture beast! I am trying to help a friend fix her Jeep right now. I think she may be having the same issue.
JeepGuy365 is offline
post #7 of 8 Old 05-18-2010, 04:38 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
A worn-out radiator cap can 'invisibly' lose coolant as well. The spring gets weak, allowing steam to escape to the overflow, where most of it evaporates before it can condense.
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #8 of 8 Old 05-19-2010, 09:49 AM Thread Starter
bobadeep
I have already replaced the radiator and water pump. I put die in the radiator but have not seen it anywhere. I will try a new cap. Thanks for the help
bobadeep is offline
coolent , leak , radiator
Antifreeze coolent leak... confused 97tjeep TJ Wrangler Technical Forum 5 03-21-2010 04:28 PM
Coolent Problems THadaway TJ Wrangler Technical Forum 6 11-14-2008 07:13 AM
Coolent leak, but where? Mrwazmo YJ Wrangler Technical Forum 7 12-28-2007 03:02 PM
Coolent Leaking and I can't find from where... 97 SRH Jeep TJ Wrangler Technical Forum 11 12-04-2007 07:43 PM
Coolent Color tennisjon2002 YJ Wrangler Technical Forum 17 11-24-2005 05:24 PM
