Coolant system issue? - JeepForum.com
post #1 of 11 Old 09-02-2013, 06:15 AM Thread Starter
PabloJeepy
Recently my Jeep has been acting weird that I suspect it's with the cooling system. After a drive, shutting down and walking out from the Jeep, I frequently here a "gurgling noise". Also, the coolant/water mixture doesn't go back to the reservoir. Checked the radiator and the coolant looks fine and engine is running at the normal 210 temperature. I've added water a couple times in the reservoir but after a few drives, its gone. Any ideas on the culprit guys?
Side note- Spending the day off to clean the Jeep (no-carpet interior, exterior, engine and soft top) and heard simple green does wonders. Input?
Cheers fellas
PabloJeepy is offline
post #2 of 11 Old 09-02-2013, 06:39 AM
oakmckinley
Try a new radiator cap.
I think Simple Green is a very good cleaner!
Welcome to the forum.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #3 of 11 Old 09-02-2013, 06:43 AM
yamaha225
Simple green is good but I personally can't stand the smell. I found one recently called "terrific pink" that I love but it's made in Maine where I live so i'm not sure if you can get it in other areas yet
1997 TJ, 2.5 4 cyl, AX-5, Hella 700's
Black Jeep Society, Eagle Scout Jeepers
yamaha225 is offline
post #4 of 11 Old 09-02-2013, 07:49 AM Thread Starter
PabloJeepy
Thanks guys, been browsing the site for Jeep advice but it feels good to be active now. I'll post results later.
post #5 of 11 Old 09-02-2013, 07:52 AM
purplepig
Mine was gurgling and I later found a leak in the water pump. After the pump was replaced I had no more gurgling.
Good luck
purplepig is offline
post #6 of 11 Old 09-02-2013, 11:33 AM
JFM626
JFM626's Avatar
Your coolant is leaking somewhere, either externally or internally.
Internally: into your engine oil, radiator, automatic transmission, or exhaust.
Externally: Water pump, hose, radiator,rad cap, heater core , thermostat housing, freeze plug,reservoir, (fill in the blank__________)
Why not open your hood when you hear the gurgling sound and see if you can pinpoint where it is coming from. It sounds like the coolant may be boiling, be very cautious of scalding water if you decide to remove the radiator cap under these conditions.
The reservoir coolant will only go back into the radiator under the partial vacuum that is created when the coolant cools, and contracts.
JFM626 is offline
post #7 of 11 Old 09-02-2013, 09:38 PM
justinyancey
check the passenger side floor board for coolant under the carpet
justinyancey is offline
post #8 of 11 Old 09-08-2013, 08:55 AM Thread Starter
PabloJeepy
Thanks guys. Bought a couple parts from ebay to see if it'll remedy the issue but gotta wait on it. Gives me a chance to take apart some things in the Jeep to learn about it more.
post #9 of 11 Old 09-08-2013, 09:08 AM
chevy2169
Be careful buying parts on ebay. You can go to Advance Auto or another parts store and rent a coolant pressure tester for a small fee. That way you don't waste money on parts you don't need.
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
post #10 of 11 Old 09-08-2013, 09:56 AM
jjvw
jjvw's Avatar
Recently mine started gurgling and would occasionally boil over shortly after shut down. Turned out to be the radiator cap which was worn out after 10 years. If you don't do a pressure test first, buy an 18psi radiator cap for $12.
2003 Rubicon
jjvw is offline
post #11 of 11 Old 09-09-2013, 11:32 AM Thread Starter
PabloJeepy
Thanks for the advice guys. Just going to go to Autozone for helps and parts now to save myself some money.
cleaning , coolant , engine , help please , radiator
