Coolant seems to be coming from rear drivers corner of tub. what? - JeepForum.com
post #1 of 8 Old 01-05-2014, 07:16 AM Thread Starter
TJJeepJosh
Have had a coolant leak for a while now that I haven't been able to track down. Oil is clean and after fixing the heater core I couldn't find any leaks underneath. Went outside this morning and found what looks like coolant in the snow under the rear drivers side of the tub. This is behind the tire just in front of the bumper. Why would that even be back there? any help
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 8 Old 01-05-2014, 07:47 AM
Jeepsr4me
did you stick anti freeze in the wiper bottle? Do you have a hard top? the hose runs back there is only thing I can come up with.
Jeepsr4me is offline
post #3 of 8 Old 01-05-2014, 07:56 AM Thread Starter
TJJeepJosh
nope no antifreeze in the wiper bottle. and yes the hard top is on. Sprays washer fluid as it should and I don't see any leaks around that area. I don't see any reason that it would be back but yet it is.
post #4 of 8 Old 01-05-2014, 07:59 AM
sjones26573
Probably running down the body. I just replaced a leaking water pump and while it was in the garage coolant had ran down the exhaust and driveline to the rear axle. Confused me for a while as well.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #5 of 8 Old 01-05-2014, 08:58 AM Thread Starter
TJJeepJosh
I was thinking it could have ran off from somewhere but its an on place to run off to. Its on both the body and the frame. I'll have to get out there and try to follow it back to find where it came from.
post #6 of 8 Old 01-05-2014, 09:03 AM
BYuen
BYuen's Avatar
Sure it's not fresh gear oil blowing out of the rear axle breather tube?
BYuen is offline
post #7 of 8 Old 01-05-2014, 09:11 AM Thread Starter
TJJeepJosh
Found out what it was... pretty stupid but at least its nothing that costs money. Went out with some friends last night. For some reason one of them left a bottle of coolant behind my back seat and its been leaking over night. Why it was there I don't know but oh well nothing I can do about it now.
post #8 of 8 Old 01-05-2014, 09:18 AM
hustler905
At least it's an easy leak to fix.
hustler905 is offline
confused , Coolant leak , help needed
