Coolant overflow tank hose leaking?? - JeepForum.com
post #1 of 8 Old 08-15-2012, 08:36 AM Thread Starter
Meng
I pressure tested my cooling system yesterday, and found out the upper radiator hose has a leak so I replaced it. topped off radiator and burped the system. After cool down I checked the pressure again, pumped it to 18 lbs and slowly dropped to 16 lbs in 2 mins and held there.. Is this fine??
When I got home last night I found white smoke coming from the radiator.. so this morning I checked the coolant level, it is not low, so I thought it was the coolant on the fan or the hoses burned off which made the white smoke. I then started the jeep, 1 or 2 mins later I found that the overflow tank hose was leaking at where it connects to the radiator cap neck.... I cant seem to find the hose on the online parts store, most of them sell the tank with the hose as an assembly. does anybody have an idea where I can buy just a hose? any part number? do autozone or advance autoparts carry it? I just dont want to wait and want to have this fixed asap..
thanks!
Meng is offline
post #2 of 8 Old 08-15-2012, 08:49 AM
Jeepsr4me
Yes they sell hose. its cheap. Measure the length and get some new hose. Nothing special about it,.
Jeepsr4me is offline
post #3 of 8 Old 08-15-2012, 08:57 AM Thread Starter
Meng
ok, I`ll check the autozone later
Meng is offline
post #4 of 8 Old 08-15-2012, 09:20 AM
MJBinNM
Sounds like you could use a new cap also...
MJBinNM is offline
post #5 of 8 Old 08-15-2012, 09:39 AM Thread Starter
Meng
I bought one yesterday and havent installed it yet... why say so?
Meng is offline
post #6 of 8 Old 08-15-2012, 10:58 AM
MJBinNM
Due to the fact that you stated you lost about 2 psi in 2 minutes...mine had a gurgling issue for a while, no real overheating issues, but a new cap fixed that. If it's not holding pressure, it will allow the system to blow off steam prematurely.
And it's something cheap to rule out...
MJBinNM is offline
post #7 of 8 Old 08-15-2012, 09:15 PM Thread Starter
Meng
thanks, i will put the new one in , but what I did was connect the tester cap to the radiator filler neck, the cap was off...so I dont know how it is ralated to the cap?
Meng is offline
post #8 of 8 Old 08-16-2012, 05:45 AM
Jeepsr4me
You could have tested the cap also. Same tester.
Coolant boiling in overflow tank chrishag TJ Wrangler Technical Forum 11 06-25-2012 02:17 PM
coolant overflow mechanics JIBTEXHNKA YJ Wrangler Technical Forum 6 07-12-2009 05:40 PM
Oil in the coolant overflow bottle?? jeepnmike TJ Wrangler Technical Forum 6 04-07-2008 12:15 PM
Radiator fluid overflow to the Overflow Tank Thunderstrike TJ Wrangler Technical Forum 2 01-16-2007 08:17 PM
boiling coolant in overflow res. ? rjcress TJ Wrangler Technical Forum 1 09-13-2004 07:17 PM
