Coolant Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Coolant Issue
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRugged Ridge Deals at JeepHut.comRough Country Lift Kits and Parts!
Unread 01-11-2015, 02:11 PM   #1
TonyTJ
Coolant Issue
Hello - I just replaced my radiator and now I have a coolant leak under my Jeep. The pic below is where the leak is coming from. Does anyone know what this elbow hose below the heater hoses is called and what it does? Coolant is dripping from it onto my frame rail then on the ground. My heater is working fine, and there is no coolant leaking inside the Jeep. There is also no coolant leaking from the heater hoses attached to the heater core. Any help will be much appreciated.
'06 LJ on 33's
'12 WK2 Limited QTII 5.7L 730N Black with Light Ash Interior.
2004 GTO
404 rwhp / 396 rwtq
TonyTJ is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 04:35 PM   #2
kdsk2071
Originally Posted by TonyTJ
Hello - I just replaced my radiator and now I have a coolant leak under my Jeep. The pic below is where the leak is coming from. Does anyone know what this elbow hose below the heater hoses is called and what it does? Coolant is dripping from it onto my frame rail then on the ground. My heater is wofine, and there is no coolant leaking inside the Jeep. There is also no coolant leaking from the heater hoses attached to the heater core. Any help will be much appreciated.
I think that is a drain tube for the tray that is
under the AC and heater cores . It keeps condinsation from the AC from dripping inside and making a wet mess . Sounds like you have a leak started inside the heater box . My 05 drops water out of there constantly because of the humidity in this area during the summer when I have the AC on.
kdsk2071 is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 04:44 PM   #3
kdsk2071
Originally Posted by kdsk2071
I think that is a drain tube for the tray that is under the AC and heater cores . It keeps condinsation from the AC from dripping inside and making a wet mess . Sounds like you have a leak started inside the heater box . My 05 drops water out of there constantly because of the humidity in this area during the summer when I have the AC on.
I'm beginning to think that possibly you couldn't build enough pressure because of the old radiator leaking and the new one holds pressure and caused the next weakest part to start leaking
Unread 01-11-2015, 05:28 PM   #4
2jhanna
that is the ac cond drian. are you sure its coolant leaking or could it be just water.
remember, your ac compressor runs even in defrost mode, causing condensation.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 05:36 PM   #5
cvaria
cvaria's Avatar
^this!
a/c drain. you are nervous. i do that all the time after i fix something. i start looking for signs of "oops"
I like my 2003 Z4 2.5i... but love my 2002 Wrangler SE and my 2007 sportster 883/1200 conversion! :rofl:
cvaria is offline   Reply With Quote Quick reply to this message
