Coolant Everywhere! - JeepForum.com
post #1 of 12 Old 02-24-2012, 03:55 PM Thread Starter
LRMark26
Coolant Everywhere!
OK its concentrated driver side under hood, suspension, and all the way down the side to the rear fender flare.
Need some suggestions. Was driving down e-way and started feeling hotter than normal (only run the vent heat doesn't work well and a/c not cold), its about 70 out today. I looked down and noticed it was running hot, just past the 210 mark. With the amount of coolant on the front fender and down the side I was expecting to see a blown hose or a hole in one but nothing. I ran it for a few minutes and still nothing. There is still coolant in the reservoir.
Is it possible that for the coolant to have come out the vent tube on the backside of the reservoir? It should not have been overfilled, its been a few months since I had to fill it up, have a very small leak somewhere, never seen a drip or smelled a leak just have to fill it up a couple of times in the last year and a half.
2000 TJ V8
LRMark26 is offline
post #2 of 12 Old 02-24-2012, 04:35 PM
vosevichs
Check top of radiator for a split by the cap. They have been known to split open.
Scott Vosevich
vosevichs is offline
post #3 of 12 Old 02-24-2012, 04:40 PM
Dice48
check your in box
KCCO
Dice48 is offline
post #4 of 12 Old 02-24-2012, 05:25 PM
Budke
when it warms up a hole in the radiator hose may open up spraying out coolant.
Just something to look for.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #5 of 12 Old 02-24-2012, 05:27 PM
Jason
Originally Posted by LRMark26 View Post
2000 TJ V8
Not dealing with stock stuff here?
Jason is offline
post #6 of 12 Old 02-24-2012, 05:40 PM Thread Starter
LRMark26
Wishful thinking... Sorry its a V6 4.0
LRMark26 is offline
post #7 of 12 Old 02-24-2012, 05:42 PM
freeskier93
I6.
And check the crimps on the radiator for leakage.
freeskier93 is offline
post #8 of 12 Old 02-24-2012, 05:47 PM
Jason
I was gonna say..... but it's an Inline 6.
Jason is offline
post #9 of 12 Old 02-24-2012, 06:06 PM Thread Starter
LRMark26
Oh man I am diggin myself deeper here yes I6....
LRMark26 is offline
post #10 of 12 Old 02-24-2012, 07:31 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yes it is.
How full are you filling the reservoir?...
Knuckelhead is offline
post #11 of 12 Old 02-24-2012, 08:28 PM
merkchop
Had mine blow some out a few weeks ago due to a dumba** move on my part. I had checked the fluid level and apparently had not put the radiator cap back on all the way. It was on, but not locked in and it blew out antifreeze, didn't take much to look like it was a lot. Sometimes it is just some dumb luck on our own part.
Just something else to check.
merkchop is offline
post #12 of 12 Old 02-26-2012, 07:00 PM Thread Starter
LRMark26
Looks like it is a leaking radiator and it got too low. Now starts the search for a new radiator.
Thanks Dice48 for the help today!
LRMark26 is offline
antifreeze , coolant , leak , over heat , over heating
coolant! JeepJeepImABeep TJ Wrangler Technical Forum 33 12-08-2010 03:04 PM
Sweet Coolant Smell but No Coolant Leak? JB73 TJ Wrangler Technical Forum 4 11-07-2010 10:56 PM
I see coolant I smell Coolant But can't find leak. MrB TJ Wrangler Technical Forum 23 07-18-2010 06:33 PM
Coolant in oil? From where??? TheDustMan YJ Wrangler Technical Forum 30 02-28-2010 06:46 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 09:24 AM
