Converting to 2003+ style CENTER BEZEL - JeepForum.com
post #1 of 7 Old 10-14-2006, 04:19 PM Thread Starter
Oman Jeep
Oman Jeep's Avatar
I want to change my head unit - the stock one just isn't cutting it now that I've been around much nicer units. I prefer the way the adapter plates look on the '03+ style, and a friend has a spare one after upgrading his to a carbon fiber one from Mopar.
Other than the trim plate for the radio, what else do I need to make it work? Can I re-use my cigarette lighter / switch area and the AC controls?
Oman Jeep is offline
post #2 of 7 Old 10-15-2006, 12:33 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Anyone done this ?
post #3 of 7 Old 10-15-2006, 12:47 AM
HTOR
HTOR's Avatar
the bezel wouldnt just be it either.
The rounded units bolt up differently than a squared unit
If you can build it, i will break it.
Team Crazy, and Mr Diameter Custom Machine.
"More Balls than you can shake your nuts at."
Jeep 1: 2000 Jeep Wrangler Sport - Its got goodies:)
Jeep 2: 1995 Jeep Grand Chero Limited - Its gonna go fast.
HTOR is offline
post #4 of 7 Old 10-15-2006, 01:25 AM Thread Starter
Oman Jeep
Oman Jeep's Avatar
Oh?
What's involved - drilling new holes or more in-depth than that?
post #5 of 7 Old 03-15-2013, 04:34 AM
mrJ
2002 KJ Liberty
does anyone know anything about swapping out the 3-switch/single power outlet in a 99 for a 20003+ version with the 4 switches and 2 power outlets? got all the switches in and wired up last night, then realized it doesn't fit in the stock location. cannot find a writeup to save my life. any help appreciated.
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #6 of 7 Old 03-15-2013, 06:38 AM
prjohnson
There's a writeup on it somewhere around here. He replaced the whole dash. If you can find one, it's not that difficult to do.
prjohnson is offline
post #7 of 7 Old 03-15-2013, 09:51 AM
Vodkaman
Probably you will have a problem with ashtray, as it is a part of the bezel. Here is a write up: http://www.jeepforum.com/forum/f20/s...stall-1234939/
Vodkaman is offline
Removing center dash bezel? GOLENJEEPTJ TJ Wrangler Technical Forum 3 12-26-2008 06:26 PM
2006 TJ center dash bezel phonewiz TJ Wrangler Technical Forum 1 04-13-2008 06:30 PM
center switch bezel sahara0207 TJ Wrangler Technical Forum 8 01-06-2008 11:44 PM
Need to find a center dash bezel somaj TJ Wrangler Technical Forum 4 12-08-2006 02:26 PM
Center Bezel somaj TJ Wrangler Technical Forum 4 06-06-2006 05:50 PM
