Control arms w/2" lift??????? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Control arms w/2" lift???????
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 09-27-2002, 11:31 AM   #1
TonyTJ
2012 WK
Are new upper/lower control arms needed when either a 2" coil or spacer lift is installed. Would useing the factory ones hurt anything or not. Thanks
'12 WK2 Limited QTII 5.7L 730N Black with Light Ash Interior.
2004 GTO
404 rwhp / 396 rwtq
TonyTJ is offline   Reply With Quote
Unread 09-27-2002, 11:37 AM   #2
'drack
You'll be fine with the stockers. Upgrade them as damage requires . I'm running 3" of lift and only have replaced the front LCA's and again, that was due to a certain encouter with some rocks .
Keith
[b]'00 TJ with some stuff[/b]
'drack is offline   Reply With Quote
Unread 09-27-2002, 11:56 AM   #3
bwheelin
i have 2" spacers and have had no problems with the stock controll arms on or off road.
bwheelin is offline   Reply With Quote
Unread 09-27-2002, 04:42 PM   #4
Jeepchik
nope no need for 'em
Green Jeep Club Member #1
Jeepchik is offline   Reply With Quote
Unread 09-28-2002, 02:06 AM   #5
kevinc
the cool thing about your stock control arms is they will twist when your suspension cycles, so you can get decent flex with them..after all they are thin stamped steel. don't forget to look into rubicon express...some good stuff there. you might end up with a long arm kit before you leave their website!
kevinc is offline   Reply With Quote
