Control arm mount help???? - JeepForum.com
post #1 of 6 Old 08-02-2010, 06:44 PM Thread Starter
Jmerante
my upper, rear control arm mount/bracket is broken and ive been searching online forever and havent found once single replacement.. idk if its the wrong name or what.. its just where the rear upper control arm connects to the frame. not the axle. can someone please give me some info or even a link? thanks
Jmerante is offline
post #2 of 6 Old 08-02-2010, 06:45 PM
Imped
Imped's Avatar
These will do:
Adjustable Frame Upper Link Bracket, 10 Degree [ADJ10U] - $72.00
OlllllllO
IndyORV
Imped is offline
post #3 of 6 Old 08-02-2010, 06:53 PM Thread Starter
Jmerante
ill have to get new control arms to fit them wont i
Jmerante is offline
post #4 of 6 Old 08-02-2010, 06:58 PM
Imped
Imped's Avatar
No.....stock will fit fine. That's a standard 2.625" mount width. Or you could go get some replacements at the dealer but they probably won't be cheap. I 'think' the mounts are at 10 degrees but I'm not sure.
OlllllllO
IndyORV
Imped is offline
post #5 of 6 Old 08-02-2010, 07:15 PM Thread Starter
Jmerante
awesome. thanks for the help. saved me a lot of frustration..
Jmerante is offline
post #6 of 6 Old 08-02-2010, 07:16 PM
Imped
Imped's Avatar
I would definitely make SURE the upper mounts are at 10 degrees before you order. You might try calling them and talking to them about your problem.
OlllllllO
IndyORV
Imped is offline
rear , uca , upper control arm , mount , aftermarket , tj , wrangler
TJ Skidplates - Control Arm Mount/Body Mount Skids ? SpaComponents TJ Wrangler Technical Forum 19 06-08-2009 01:50 PM
Dana 30 control arm mount Jeremy99 TJ Wrangler Technical Forum 4 12-28-2008 07:22 AM
Bad bushing, control arm, mount or ??? dspmans_04_X TJ Wrangler Technical Forum 9 02-14-2008 04:59 PM
Control Arm Mount jb95gst TJ Wrangler Technical Forum 1 04-24-2007 01:36 PM
control arm mount TSWRA TJ Wrangler Technical Forum 10 02-15-2006 12:17 AM
