Control Arm Joint Orientation - JeepForum.com
post #1 of 12 Old 09-18-2011, 06:20 PM Thread Starter
1Bad
Hey,
I don't know much about suspension geometry so I want to ask you guys. This picture is taken on flat ground/ Is it ok that the control arm joint be tilted like that? My guess is that under flex this could cause binding and that ideally the joint should be straight when on flat ground, but I want to make sure.
1Bad is offline
post #2 of 12 Old 09-18-2011, 06:25 PM
dkrajcovic
it will bind under flex like that
it is best to have it staight you can do this by loosing the jam nut & turning it untill it looks staight ( & hold the joint when you retiten the jam nut
dkrajcovic is offline
post #3 of 12 Old 09-18-2011, 06:27 PM
biffgnar
biffgnar's Avatar
What kind of joint is on the other end of the arm?
Romney in 2020!
biffgnar is online now
post #4 of 12 Old 09-18-2011, 06:30 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Depends on what's on the other end of the arm and without knowing that, you can make no judgements.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 12 Old 09-18-2011, 06:30 PM
dkrajcovic
looks like Johnny Joints to me
post #6 of 12 Old 09-18-2011, 06:31 PM Thread Starter
1Bad
both ends are johnny joints. They are savvy control arms. The other end is not orientated the same way, I will correct them so that both ends have the same orientation. That way they should have the most freedom to rotate any direction.
1Bad is offline
post #7 of 12 Old 09-18-2011, 06:32 PM
biffgnar
biffgnar's Avatar
Then as long as the joints are oriented the same on each end it is completely normal. Don't worry about it.
Romney in 2020!
post #8 of 12 Old 09-18-2011, 06:33 PM
dkrajcovic
well yes u r righ if they both ends
post #9 of 12 Old 09-18-2011, 06:37 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Loosen the jam nut, rotate the joint bodies back against the side of the mount that that will stop them from turning when you tighten the jam nut and then tighten away. That sets both joints perfectly in alignment with each other and after that, don't worry how they ride.
I am Savvy
mrblaine is offline
post #10 of 12 Old 09-18-2011, 06:39 PM Thread Starter
1Bad
K, thats what i figured, it doesn't much matter that they are centered but that both ends have the same orientation.
1Bad is offline
post #11 of 12 Old 09-18-2011, 06:51 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you had balls of steel, would you care about your orientation?
I am Savvy
mrblaine is offline
post #12 of 12 Old 09-18-2011, 07:05 PM Thread Starter
1Bad
1Bad is offline
Combining stock control arms with Johnny Joint control arms alex_c TJ Wrangler Technical Forum 3 09-10-2010 09:55 AM
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 10:59 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 12:27 AM
Lower Control Arm Installation Orientation -- Does it Matter? newgene TJ Wrangler Technical Forum 8 06-15-2005 08:58 PM
regular control arms vs. heim joint control arms. lucasinpsj TJ Wrangler Technical Forum 7 10-27-2004 02:35 AM
