Control arm bushings same size? - JeepForum.com
post #1 of 2 Old 07-08-2010, 08:09 PM Thread Starter
ssb
2015 JK Wrangler
I need to replace my rear lower control arm bushings on stock CA. napa says they only have the front ones and don't see a part for the rears. Are they the same size or do i need to speak with someone else at the Napa Store. I found them on their site so i can't see how they would not have them. What say you?
ssb is offline
post #2 of 2 Old 07-09-2010, 07:48 AM
JeepN95YJ
The lower control arms use the same bushings front and rear.
Upper control arms use a smaller bushing.
JeepN95YJ is offline
control , arms , ca , lca , bushing , replace , replacing
Teraflex control arm bushings and rear track bar bushings Robbypfd TJ Wrangler Technical Forum 5 02-15-2011 03:55 PM
Control arm bushings. Secret_Squirl TJ Wrangler Technical Forum 7 11-23-2009 02:09 PM
Control arm bushings Wrangler_91 TJ Wrangler Technical Forum 21 06-25-2008 05:24 AM
Help! control arm bushings Rubicon153 TJ Wrangler Technical Forum 0 09-08-2007 10:10 AM
Control Arm Bushings 97JPTJ TJ Wrangler Technical Forum 4 05-31-2007 10:46 AM
