Quantcast Continuing AC Vacuum Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Continuing AC Vacuum Questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 07-06-2007, 12:53 PM   #1
braddock
I had everything you can imagine wrong with my AC vacuum system. I found the vacuum line going to the panel actuator had come unplugged. Fixed that. Then I found that the plastic actuator arm itself had broken off. Fixed that. I had perfect AC for about two weeks. Today nothing. I took a look under the hood and traced the vacuum line from the top of the air intake over to the passenger side firewall where it t's off and enters the firewall. The line going into the firewall is okay, but the line going past the T is just hanging there. I can't find where it should connect. When I zip tie this line closed my vacuum is restored and the AC works fine again. This line must go somewhere and effect something though. Sorry for the long story and thanks for any help.
braddock is offline   Reply With Quote
Old 07-06-2007, 01:24 PM   #2
97_tj
i had the same problem on my rig the plastic line goes from the t connector to a canister that is mounted under your battery tray if you look at it will have a short rubber hose on it and it connects to the plastic hose and ps the plastic hose is 5/32 id
97_tj is offline   Reply With Quote
Old 07-06-2007, 02:11 PM   #3
braddock
I think I found the box underneath the battery and where that vacuum line should attach. What is the function of this box though? The AC is working perfectly without the connection.
Old 07-06-2007, 02:23 PM   #4
97_tj
it is a vacuum storage canister it needs to be hooked up for the hvac system to work properly as your engine rpm varies
Old 07-06-2007, 02:24 PM   #5
braddock
Okay, I found out the box under the battery tray is the vacuum reservoir. It appears to be a bit like an appendix and not necessary except under extreme circumstances. I am going to let things ride like they are with the vacuum line to the reservoir crimped until I have the time to take out the battery and tray to access the reservoir.
Old 07-06-2007, 02:26 PM   #6
braddock
Thanks for the help 97 tj.
Old 07-06-2007, 03:02 PM   #7
97_tj
i did not have to pull my battery out i crawled underneath the body and saw where mine broke off at and i replaced the hose and vacuum line in less than 3 minutes just be sure to wash your hands good afterwords
Old 07-06-2007, 04:43 PM   #8
braddock
I can feel the connection, just can't see it from under the Jeep. This should keep for a while. At least the AC works. Cold air sure does feel great on a rainy, top-up, and humid Mississippi day.
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
