Constant Creaking - JeepForum.com
post #1 of 4 Old 12-06-2008, 06:16 PM Thread Starter
NorthernRebel
Constant Creaking
Hello everyone! New Forum member here.
I just purchased a 2000 Wrangler. V6 automatic. Has a 4" lift with 33 X 10.5 tires. Here's my question. The Jeep creaks quite a bit when either coming to a stop or starting off. Is this normal, or should I begin looking for the cause of the problem? I don't mind the creak so much, as long as I know it's not a sign of a bigger problem.
Thanks for any help you can provide.
NorthernRebel is offline
post #2 of 4 Old 12-06-2008, 07:30 PM
Hilltop
start by checking all bolts on lower control arms, front and rear trac bars, front and rear sway bars and sway bar links. if there are grease fitting on the control arms grease them. and check the bushings for wear. also check your u-joints.
Hilltop is offline
post #3 of 4 Old 12-06-2008, 07:47 PM
nettak
It's probably creaking because you have that rare V6
'03 Rubicon, RE 4.5" LA with 1" BL and 1" MML, RE Monotube shocks, 35" Nitto Terra Grapplers, Warrior Products safari rack, ORFab tire carrier w/ HiLift and gas cans, Warn M8000 winch, Warn rear bumper, Fabtech front winch bumper, IPF/Fatboy headlamps with homemade wiring harness, Ruff Stuff heavy duty diff covers, Kilby cargo rack, AtoZ rockers, Bestop trektop nx
Ain't no ghetto bling Jeep!
nettak is offline
post #4 of 4 Old 12-06-2008, 09:11 PM Thread Starter
NorthernRebel
LMAO
Ooops, I guess I meant straight six.
constant 12V NJscott TJ Wrangler Technical Forum 2 03-28-2009 03:26 PM
Constant hot air from vents bctj TJ Wrangler Technical Forum 2 03-24-2009 08:58 AM
no constant hot for radio uglyoldbob YJ Wrangler Technical Forum 6 02-15-2009 09:57 PM
12v+ Constant under the dash? Windsma YJ Wrangler Technical Forum 2 04-12-2008 06:26 PM
Constant Leaks! RipcordAFF TJ Wrangler Technical Forum 10 09-12-2005 02:36 PM
